Question about Car Audio & Video
Dashboard lights I need to replace 8 lightbulbs on the dashboard of a 2002 Dodge Grand Caravan. It appears that there are two screws in the center of the instrument cluster. When I remove them, what kind of brackets am I going to have to deal with to remove the plastic on the speedometer assembly to replace the bulbs? I'm afraid to snap the brackets.
  • dahockeypuck Mar 01, 2008
    Thanks agu621. Once I removed the instr. cluster, I noticed the bulbs in the rear of the cluster. A 1/4 twist and out they came. I replaced/tested each one at a time. Whole job took under an hour.
    Thanks again.
You need to remove th whole inst. cluster to replace the bulbs that are located on the BACK side in bulb carriers. Usually turning a 1/4 turn to the left reomves the carries in order to replace the bulbs. Some manufactuers, you have to replace the bulb carrier/socket and bulb as a unit , others just pull the bulb and replace with the SAME type bulb as removed. Most instrument carriers will have on the back what the particular bulb in a specific position is used for by a symbal and the wattage for the also ie: 2.5, which is 2.5 watts. In remove ing the cluster be very careful removeing the connectors from the back. There are certain ways each has to be released to come off but usally can only go in a certain location in the cluster, just make a mental note to yourself has you disconnect them and you will be fine. Alan
Posted on Mar 01, 2008
I need to know how to access light bulbs in the center panel where the heater controls are. Initially only one control backlight was out. Now light behind the rear control switch is out. Thanks
Dodge Caravan (01-03) Instrument Panel light replacement ...
? 12:25
https://www.youtube.com/watch?v=d9qi78IAPF0
Mar 4, 2013 - Uploaded by ryanthiusjunk
A common issue with the Dodge Caravan (and Chrysler Town ... I just bought a Dodge Grand Caravan (2002) and noticed that the entire dash board didn't light up at night. Needless to say I needto replace all of those bulbs and after ... do you know how to fix the 2009 caravan instrument panel lights going ...
DIY Dashboard Light Bulb Replacement - YouTube
? 8:07
https://www.youtube.com/watch?v=_bf5w3AZR_0
Jan 7, 2013 - Uploaded by Chris Punt
How to replace dashboard lights on a Dodge grand Caravan. ...Most just want to get the bad bulb out and put new one in. it seems to me the ... pull the dash panel out far enough to turn it upside down on the column and ... Bought mine at Advance Auto, but I know it is not a hard bulb to find and can be ...
2001-2007 Dodge Grand Caravan/Chrysler Town and ...
Dec 13, 2015 | 2005 Dodge Grand Caravan
Grand caravan problems
I'm assuming fuses are all checked and good. Even though your grammar and spelling isn't. To me, it sounds like a voltage regulator... Or very possibly a short circuit in the ignition circuit. I'd check voltages from the alternator while the car is running. Then check voltages on the dashboard (center console controls should be easy to get to, the bezel just pops off after two screws at the bottom are removed). If the alternator voltage is good (12.5-15V is my guess), but the dashboard gets much less, then the voltage regulator may be having an issue. I'm not sure if that's an independent part or part of the ECM (the computer). If the dashboard gets nothing, I'm betting a short circuit on the alternator current... Check wiring at pinch points under the hood.
Jun 09, 2014 | 2003 Dodge Grand Caravan AWD
Dashboard lights not working
Try and look under the steering wheel area for a fuse block. When you pull off the cover there should be schematics on fuses. Go 1 by 1 pulling them and replacing if ok, otherwise replace the ones tht are bad.
Mar 01, 2011 | 2002 Dodge Grand Caravan
Where is the fuse for the dashboard for dodge grand caravan 2002
Most of the fuses are under the hood, next to battery has a plastic cover, take it off a look under cover, it has a diagram of all the fuses. Good Luck.
Oct 03, 2010 | 2002 Dodge Grand Caravan
All dashboard/ center console lights out.
Test the dash first. Put key in hold down trip reset botton. Turn the key to on but don't start. Release the trip botton. Should turn on all dash lights & check for codes in the odometer. If getting codes reply back.
Feb 11, 2010 | 2004 Dodge Caravan
Warning light on dashboard
Hi There! This is the tire pressure monitor letting you know that one of the tires is low on air. Thanks
Aug 04, 2009 | 2008 Dodge Grand Caravan
Some Dashboard Lamps Burned Out
get a repair manual from your local auto parts dealer or go to the library alot of times they keep repair manuals for different makes of vehicles
Jun 22, 2009 | 2005 Dodge Grand Caravan
Dashboard lights don't work
Make sure that when you check the fuses you use a test light applied to both sides of the fuse you are testing.It can be very difficult to see a fuse that is blown when the fuse is blown near the edges. PS the dash fuse is by itself and needs to be checked when the light switch is on.
May 26, 2009 | 2000 Dodge Grand Caravan
I hate to sugest something so minor , but if it helps you out I will , no offence I hope.
Is the dimmer dial turned right down ?
May 05, 2009 | 2000 Dodge Grand Caravan
Model 2002 dodge grand caravan sports dashboard not working speedometer, tachometer and fuel gauge
If you look under the dashboard on the driver's side, there is a fuse panel. Under this panel is the BCM(body control module). There may be a bad relay in the bcm. Worse case scenario is a bad BCM. I hope this information is helpful to you, Good luck.
Apr 16, 2009 | 2002 Dodge Grand Caravan
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
