Question about Watches
Casio Marine Gear (2413)
I opened the case for battery replacement and now I have 4 different springs I don't know where to put during reassembly. Can someone help me with this stupid problem?
  • nicknametake Apr 19, 2008
    hello, for my part,the trouble is that after changin the batteries, it does not work any more... but i can tell you where their place is
HOW DO YOU REPLACE A BATTERY ON A CASIO 1572 A168
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
Chris
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.
Feb 26, 2013 | Casio A168W Wrist Watch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How to change the battery in a CASIO CA53W-1 Watch with Calculator
    open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
    there is a spring inside that goes betweeen one of the contact holes. dont know which.
    Jun 03, 2010 | Casio Watches
    My casio marine gear is 6 months old and started losing 5 minutes. what can I do?
    Speak to your local Casio dealer, it could be that the battery needs replacing, (some watches can need replacements if they have power hungry features which have been used frequently.
    If this is not the case, then if there is anything wrong with the watch, then it should be repaired under warranty.
    Mar 01, 2010 | Casio Marine Gear AMW320D9EV Wrist Watch
    Replaced battery and it says OPEN
    I know the secret that CASIO is hiding behind this thing. If your watch shows "OPEN" then you don't have to go to a CASIO retail store. You don't have to send your watch with money to CASIO or go to an Authorized CASIO Service Center. I know how. Just send me an e-mail to s.duteau@videotron.ca and believe me you'll be happy to know the "SECRET" an get rid of this annoying "OPEN" over with. You want this fix! Than don't wait.
    Oct 27, 2008 | Timex T46821 Wrist Watch
    Loose spring popped out from behind....now I have no sound!
    this video will show you were the spring goes next to battery
    Jun 14, 2017 | Casio G-shock G2300B-1V
    I had my battery replaced in my Casio G Shock DW -6800. Since then the beeps and alarms are not working. Is there some sort of reset button he forgot to press?
    There are two internal springs that contact the back cover of the watch through an insulator. The alarm nor chime will work if they were not put into their proper locations or were omitted during reassembly.
    Apr 24, 2008 | Watches
    Watches Logo
    649 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
