Car Speakers and Subwoofers
Problem for Car Speakers and Subwoofers
Generic problem for all Car Speakers and Subwoofers
90cc quad bike (chinese we think)
By Beccax on Mar 01, 2008
Hiya i wondered if you could help me, when we are connecting the battery to our quad its turning over with no key, can anyone tell us why, there is no short or any wires touching! Many Thanks
Comments:
Mar 01, 2008
- Hiya Benimur, is this the starter/relay box you are talkin about? Thanks
Mar 01, 2008
- Tryin to put pic but it wont let me?
Mar 01, 2008
- Yes we have replaced it but still the same, could it be something to do with a earth wire touching live, or the immobiliser, thanks for all your help,
Mar 01, 2008
- Hiya yes it is, but we have now replaced it and its still the same. Could it be something to do with a earth wire touching a live or the immoboliser, many thanks
Mar 02, 2008
- Thanks for all your help, this really helped us and we are pleased to tell you that its now running, many thanks
Best Solution
posted on Mar 01, 2008
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3831 votes
If I understand your concern right, whenever you connect the battery, the quad's starter motor will run even when the ignition is OFF.
The only possibility I could think of is that the starter relay's contact are fused together. Normally, the relay's contact should only connect when the ignition is on, the starter button is pressed and I believe in some versions/models, one of the hand brake levers is pulled in.
Since these products come in two (2) versions two stroke and four stroke and manufactured by quite a number of firms, there is no standard repair procedure.
If the big red or + wire from the battery goes to the starter motor directly, then the possible fused contacts are inside the motor assembly itself but distinct from the motor;
If the big red or + wire from the battery goes to a squarish small box, which is a power/starter relay, then the possible fused contacts are inside that small box. That box would have two big wires, one from the + of the battery as earlier stated and another going to the starter motor. Additionally, it would have 1 or 2 smaller wires. One would go to the starter button switch and the other to the ground. It is also possible that it is connected to the ground if it has got a metal body and therefore would only have 1 small wire.
If you have verified that it is the latter (using a relay), then you need to replace that relay.
In some instances, it could be the starter switched that has fused together its contacts though this rarely happens.
If your concern has not been corrected after completion of the above procedures, try to pls post back with pictures of where the + big battery wire goes to.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comments:
Mar 01, 2008
- and hi again Beccax ,
Yes it is. It is not uncommon for the contacts inside the starter/relay box to be fused together (assuming your quad is using one).
Mar 01, 2008
- There is a limit to the file size of the picture/photo that the 2nd icon "Insert Image" will allow. It's got to be 150kb or less. You need a photo editor software to compress the photo image from your digicam. This is better explained here.
Mar 01, 2008
- Beccax,
Is it something similar to the image below?
Mar 02, 2008
- Appreciate for the update.
Since you have replaced the relay and the problem persist, pls try removing the two smaller wire connector. If the starter motor will stop engaging then the problem is a bridge or a short in the "push to start" switch or a short along the start B+ wire to a live B+. The two smaller wires provide the: a) ground connection and the b) start B+. Normally the ground wire is already grounded and the start B+ goes to the "Engine Start" or "Push to Start" switch. This switch in turn will only have a +12 on the other end if and only when the IGN switch is turned on. Therefore we can suspect that the start B+ line is shorted to the always on B+ somewhere.
There are cases where the reverse wiring arrangement is used, i.e. the ground is the one being switched on to the chassis.
The "immobilizer" is a "Kill Engine" switch and switches the ignition OFF. This is a separate from the start wiring. It normally grounds a wire from the CDI to deactivate it.
Perhaps the simplified wiring diagram below would be of some use to you.
Cheers.
Mar 02, 2008
- Glad that it is up and running. Appreciate the rating too.
Was this helpful?
Yes
No
Popular Solutions for Car Speakers and Subwoofers
Questions and Unsolved Problems for Car Speakers and Subwoofers
Answer
if u want a deep loud base sound and clear what woffers and door speakers.
Answer
what is the best 12 inch earthquake speaker (subwoffer)
Answer
im intrested in buying 2 15'' Kicker CompVR 07CVR154 speakers, and i'd like to have the best idea... (More)
Answer
My L7 stopped putting out bass. Itmakes this terible noise when I raise the volume. It's a 4 ohm and... (More)
Answer
i got a new car & the set only works for a few sec. then restarts all over can u help set #... (More)
Describe your Car Speakers and... problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Speakers... Experts
Top Audio & Video Equipment Repairmen
in , PA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
