Question about Samsung TS-H492 (TSH492AWRBH) CD-RW/DVD-ROM (Combo) Burner
Samsung TS-H492 Jumper
I've been given a DVD-RW by a friend to replace a faulty one.
I can put a DVD in the drive but Windows XP doesn't see it.
I presume the jumpers on the back aren't set right.
My HD is set to cable select. How do I set the jumpers for the DVD drive?
  • CarlNE Mar 02, 2008
    Hi. I discovered the meaning off the jumpers (on top of the drive).
    The HDD was set to Cable Select and the DVD driv to Slave.
    I changed the jumpers to Cable select and the BIOsnow recognised the drive.
  • Anonymous May 30, 2008
    When I put a cd in the drive you can here it turn on but the computer won't recognize it. I went to the device manager and it does not show the cd dvd drive is even there.
  • 75 Answers
if u have two seperate data cable to hard disk and dvd rw,there is no big changes to made in jumpers,but u have only one data cable u should select jumper as a master to hard disk and slave to dvd rw,
basic identification to master jumper is that ,it place is close to data cables ,and slave is next pin,in typical models
also u se the detail in hdd and dvd rw's jumper locations
Posted on Mar 01, 2008
I can`t see my rom in my computer an it won`t load up anything
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' on it your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
Feb 27, 2011 | Samsung TS-H492 (TSH492AWRBH)...
How can i burn dvd in combo ts-h492,
you can not burn a dvd with a dvd rom you will need a dvd-rw not a cd-rw
Dec 22, 2010 | Samsung TS-H492 (TSH492AWRBH)...
Need diagram info for master and slave driver
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Dec 06, 2010 | Samsung TS-H492 (TSH492AWRBH)...
I am looking for info on how to remove the driver
Here's a good tutorial on updating windows drivers, that may give you the information you're looking for.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 23, 2009 | Samsung TS-H492 (TSH492AWRBH)...
My samsung ts-h492 does not read cd
you'll have to clean the lens with the help of a service engineer...even after the same problem occuring means you'll have to check the data cable...if found any error replace it...
Jul 05, 2009 | Samsung TS-H492 (TSH492AWRBH)...
Drive not working
try to check the connection of that device of it is properly attach.
Jun 16, 2009 | Samsung TS-H492 (TSH492AWRBH)...
Computer turns off due to new installed hardware (cd-rom drive)
Then only one more check to do before we can fault the new unit , the new unit should have jumpers at the back of it. If it is the second unit of that type installed ensure the jumper settings is set to slave and not master which is default. If it is the only unit (cd rom/dvd rw) then you have a faulty new unit. Best way to is to insert in another friends machine to double check before taking it back.
May 12, 2009 | Samsung TS-H542A DVD±RW Burner
I have a question, I install a Hard Disk as a slave with the CD ROOM data buss, but when I turn on the pc the cd room wont be recognized, What would you recommended
Do you have both a primary & secondary IDE controller? Make each Master on its own controller. Or make the hard drive master with the DVD as the slave on the same controller.
Mar 04, 2009 | Samsung TS-H492 (TSH492AWRBH)...
Samsung TS-H492 CD-RW Combo
are you using a single IDE cable with your H/Disk? if yes! check, the jumper connections of your CD-ROM,maybe the are both in the master position ,change the jumper of your CD_ROM to slave position.or use another cable for your CD-ROM.if doe'snt work go to BIOS SETUP,set the settings to default SETUP.then restart your PC.
Mar 10, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Samsung TS-H492 (TSH492AWRBH) CD-RW/DVD-ROM (Combo) Burner Logo
1,243 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
