Question about NetGear DG834 Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only get a local connection (desktop win xp, laptop vista)
  • 2 more comments
  • AVP909 Mar 01, 2008
    wireless adaptor atheros ar5006x
    I've connected to the network but local access only (entered passkey, etc.)
  • cathypell Nov 10, 2008
    I have been using my laptop with wireless fine for months until I Turned it on today and now it will only connect localy? I have tried evrything an restaring everything but noting works ? I have another laptop that is working fine so itmust be something in the setting on the laptop just dont know what i have looked and they look the same?
  • Rohit Chadha
    Rohit Chadha May 11, 2010
    Which wireless adapter you have on your laptop, is it enabled, have you tried to manually configure the wireless WIFI on laptop??????
  • Anonymous Mar 30, 2014
    we have a house guest who is trying to connect to the internet via our wireless router
None of those solutions work. thanks for helping anyway
-avp909
Posted on Mar 27, 2008
    Problem Solver:
  • 11 Answers
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
2 Suggested Answers
  • 9 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Posted on Dec 22, 2008
I have an hp comp that wont connect to my netgear internet access
Define/explain "wont connect".
Are you trying to use an Ethernet cable to connect the two devices? If so, try a different cable, to rule-out a "bad" cable.
Do you have any software like "Norton Internet Security" on the HP? It is notorious for "blocking" attempts to connect to "unknown" networks.
Does your desktop computer have a wireless networking adapter that you are trying to configure/use?
Will any other computer, either via Ethernet cable or wirelessly, connect to the NetGear router? If not, then maybe the NetGear is the problem.
Any error-messages when you try to "connect" ??
Exact wording?
Sep 07, 2010 | Computers & Internet
No wireless connection
Dont enter the Router IP as WWW.192.168.0.1, Instead just type 192.168.0.1 and it should let you access the Router EWS Page. you are trying to access Internal network ( which we can call local network or LAN ) so do not use WWW.
In the Address bar of Internet Explorer, just type the IP Address.
Jun 24, 2010 | D-Link AirPlus DI-524 Wireless Router
Unable to connect EpsonTX710W Printer viaNetGear DG384
On your Laptop go to Control Panel-> Printers-> and then add printer. Select the option of network printer and search for your printer. If found add it.
Or Else check the ip of printer from ports tab in printer properties on desktop computer ans search your printer with ip address on Laptop.
Jun 01, 2010 | NetGear DG834G Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Setting up a wireless lan
The DG834PN is an easy to set-up, single box solution, it plugs straight into your ADSL line – there is no need for a separate modem. Once the DG834PN modem router is connected, configuration is also easy, via NETGEAR’s Smart Wizard™. The Smart Wizard™ automatically detects your ISP’s network settings, and then walks you through each step of the installation process. Or then Call ur ISP.
Thank You,
Your Tech Support,
Fixya.com
Manish Shirsikar
May 18, 2009 | Gigabyte GA-K8NS Motherboard
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Hit apply and exit
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Problem with adsl connection
Yes, just connect them via an ethernet network cable
Aug 09, 2008 | NetGear DG834 Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
No access to internet via wireless or ethernet
Check ADSL is active and connectted on the router.
Use webmanagement link the link below.
http://192.168.0.1
username: admin
password: admin
If the above details does not allow you to connect, check under the router for correct details.
Mar 11, 2008 | NetGear DG834G 802.11G Wireless ADSL...
NetGear DG834 Router Logo
1,311 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
