I can't get my Motorola Bluetooth Headset H700 to connect to my sony ericsson w300i phone. i don't have the instructions for the bluetooth anymore and it is a new phone, and i can't get them to connect. do you know how to connect them or where to find a copy of the instructions? thanks
you can connect your sony ericsson t616 to your motorola h700. for that you have to switch on the bluetooth in your phone then you must switch on your bluetooth headset. after that from your phone select the option "search for any devices". but i would suggest that you can go for a sony ericsson bluetooth headset instead of any other brand,because motorola might not be compatible.
Hold down the connect button on headset
until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000".
Now the H700 will show up in the Bluetooth device list, but it will not
connect.
Put the headset in pairing mode again, this time go to the h700
listed on the phone and select connect. Now the devices will work
as normal. When you open the boom on the h700, it will connect to the phone.
connect.
1. Bluetooth enabled? 2. Options -> Bluetooth -> Add Device
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000".
connect.
listed on the blackberry and select connect. Now the devices will work
blackberry.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H700 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset
The phone identifies and maintains up to 16 devices which are displayed
in a list. To add a new device or pair a headset via bluetooth, turn
Bluetooth™ on in both devices.
Put headset in pairing mode. See Headset User Guide for more information, if needed.
Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
Choose [TURN ON] , press "Select"
Choose [MY DEVICES], press "Select"
Choose [NEW DEVICE], press "Select"
Choose the headset to be paired and press ' Select '
Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
