Question about Canon imageRUNNER 400S Copier
To set scan
I have ea 1r400 with printing facility. i want to setup scanning on is. i ran scan set up . when scaning it asks for IP address what is the IP address
  • jeff heightchew
    jeff heightchew May 11, 2010
    the ip address is the unique address your "it" person would/should assign to your copier.It is very much like a street addess or a phone number. If you had a box of chocolates to deliver and there was a particular person/house/address where they needed to go, you would need to know the persons address. Or if you wanted to call an individual and say "HEY! U won the lottery !" you would need a specific phone address (phone number) to make sure you called the right person to let them know this important information. The wrong address(phone number) could really cause problems. Your ir400 does not come with an address. It is assigned an address by someone (your IT guy/gal).This would be the person who helps make your network run as it should, and makes sure that only one device has the address (ip) that gets the chocolates and the million dollars. I know I did not solve your problem but I hope I have given you a better understanding of whats going on. Take care and live well!.............Spinal
    Problem Solver:
  • 8 Answers
On most printer/scanner equipment there is an user tools or options icon or button. Look in there for system settings,sub-section interface settings.That is where you will find your devices IP address. Be very careful not to change these settings, just look don't touch.
Posted on Mar 04, 2008
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Dec 31, 2010 | Canon imageRUNNER 400S Copier
Our computer maintenance company was able to set up our scanner about three months ago. Over the weekend we have lost that capability. We are receiving an error message: Setting how do I fix scanning...
Click this LINKfor the Scan to SMB setup guide which will walk you through the settings. If it had been working then stopped most likely just one setting has changed; the two things I would look at first is the password for the folder you are scanning to and and IP/Host Name of the computer you are scanning to.
Does your Domain require you to change your password on a regular bases? If so then the password set in the copier to access the folder on the computer may have changed and the new password needs to be set in the copier.
Also the person that setup the scanning originally may have set it to scan to the IP address of the computer you are scanning to but if the computer is setup for a dynamic IP address the IP will change from time to time and then the copier will not be able to find the computer you are scanning to. Change the IP that the copier is set to scan to, to the Host Name of the computer you are scanning to and that will no longer be an issue.
The Scan to SMB setup guide goes over these settings.
You can also call Kyocera's free help desk Monday - Friday 9 am - 6 pm EST at: 1-800-255-6482.
Dec 20, 2010 | Kyocera Km-3060 Mfp Copier Copy Machine...
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
Ir5020
Was scan vgear setup? you have to enter the ip address for the copier in the setup. If you can print to the copier, use that same IP address in scangear and you will have communication.
Jun 24, 2009 | Canon imageRUNNER 5020 Copier
Scan to email does not work dell a960. it will copy, print but the scan does not work all of a sudden. It doesn't work thru the feeder or just by placing the paper on the glass. It will not scan to a file...
well scan to email or file depends on the setting your putting if its right or wrong, the machine should be hooked to network and has ip address, browse the ip address of the machine and setup the information, and try it.
Jun 17, 2009 | Dell A960 All-In-One InkJet Printer
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have a DPR-1260 usb print server. set up a breeze for PC's but cannot get macbook to identify it. Getting no where fast with wireless printing an macs. Help
  1. To make sure your Mac can see the print server, open up your favorite browser, and enter the IP address of your print server, as assigned by DHCP on your router into the URL box. (My router assigned the IP address 192.168.0.100.) On this web page, be sure to note the IP address and LPR queue name.
  2. Open up the Printer Setup Utility (/Applications/Utilities/Printer Setup Utility).
  3. Hold down the Option key while clicking on More Printers...
  4. In the next dialog box, under Device, choose LPD/LPR Host or Printer.
  5. In the Device Name field, give your printer any name you want. Since my shared multi-function printer is an HP PSC 2110, I simply named mine PSC2110.
  6. In the Device URI field, enter the following: LPD://IP_Address/LPR_queue_name, using the information gathered in step two. For example, mine was LPD://192.168.0.100/PSC2100Series.
  7. To be able to use the shared scan features, create a bookmark to http://IP_Address/scan.html (e.g., "http://192.168.0.100/scan.html" for my setup), so you can operate your scanner from a web interface.
Jun 10, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can't scan with mfc-7840 w, has worked fine for months, on laptop with xp, was working in another office for last 10days, came back to home office and it can't recognize device at all I can ping IP no...
I had a similar problem. I was able to print and scan for months and then all of a sudden could not scan anymore (from printer or through software interface). I then found out that the IP address for the scanner was not set properly. To fix this, goto control panel and scanner and cameras. Right click on the MFC7840W and select PROPERTIES. On the network setting tab, make sure that the IP address is the same as that on the MFC7840W.
Mar 31, 2009 | Brother MFC 7840W Printer
Setup scan to pc function
Find the scanner on the network... you can use a tool like Advanced IP Scanner to search the subnet and then just hunt down the IP that belongs to the device -- it may not have a name registered.  Visit each potential IP via browser (http://192.168.1.50), one will show you the Kyocera web page.  The device has two, one for printer, one for scanner.. each one on its own IP....
That's how far I've got with mine - i was hoping it supports SMB scanning, but it may not.  So now I am looking for the rest of the setup.
Dec 08, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Unable to print
I have had the same problem. 2 computers had been able to print fine then 1 stopped (other was still fine). I use Network Magic as well- noticed that the IP address for the print server was different on each computer.
I deleted the 2 printers on the computer that could not communicate to the server, logged into the server and set its IP address to static at the address listed on the computer that could print. Next ran the set up for the printers on the problem computer again.
Test pages now printed out fine.
Mar 25, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Canon imageRUNNER 400S Copier Logo
144 people viewed this question
old marine
old marine
