Question about NetGear WGR614 Wireless Router
SECURITY BREECH,HOW CAN I CHANGE MY USER CODES?
I HAVE A SECURITY BREECH ON MY BROADBAND WIRELESS NETWORK CAN I CHANGE MY USER CODES?
How do I add my security code. My hard drive went bad and my wireless conection wont work
Posted on Sep 24, 2008
    Scholar:
  • 47 Answers
Step One : open the web browser and type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Two: it would ask you for username and password. enter Username : admin and Password : password .
Step Three : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the configration to come on the right side.
3) On the right menu now click on wireless settings in the setup section.
a) give a SSID name that is a name you want to see when connecting to the the wireless router while connecting from a wireless device. E.g. ( "mp's netowrk",etc.)
b) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced tab and click on LAN IP Setup.
a) In LAN Tcp/ip setup change the ip address to : 192.178.1.1 (to avoid dsl ip conflict)
b) there should be a check on use router as DHCP Server.
Starting IP Address 192.178.1.2
Ending IP Address 192.178.1.7
(the ip range should not be more that five ip address as otherwise the performance output would be pathetic)
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you laptop or wireless card in your computer and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Posted on Mar 16, 2008
    Problem Solver:
  • 8 Answers
I am not sure what you mean by User Codes. But you can try changing the SSID and secure it with a new password. Buy a broadband router that includes a built-in firewall, even if your broadband provider doesn't include one with the service package. Secure your wireless network with WPA or WEP. Turn your wireless off when you are not using it. This will prevent others from trying to use your wireless network. Try to check who is using your network and block him or her.
That is all the advice I can give you.
Good Luck.
Posted on Mar 08, 2008
Set password
Download the user guide from here
TRENDnet Support TEW 452BRP 108Mbps Wireless Super Broadband Router
1. Go to Wireless on the management menu.
2. Got to Security on the next menu and change the wireless security from disabled to your choice of security setting and then follow the prompts. Page 31
Apr 19, 2014 | Trendnet 108Mbps Wireless Super G...
Tip
How to reset your linkseys wireless router wep key.
Press start on your computer
click network
right click on the router
click on view device web page
leave user name blank
password - admin - ok
click wireless tab
change wireless(ssid) network name (anything will do, it will assign you the correct one) write the name down.
click reset security, wait till it fully uploads
click save settings
when the page reloads click on security mode - wep
enter 10 didgit code, letters and numbers: ie: abcde12345 (write down the number)
save settings
back to network on the start menu
setup connection or network
manually connect to wireless network
enter network name
enter security key
highlight the one you want
click connect
on Jan 31, 2010 | Linksys Wireless-G Broadband Router
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I forgot my user mname and password for my wifi connection
You can secure your wireless network wit WEP or WAP code.
For know your security key Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
The old password is in * or # format so you need to enter new password.
Let me know if you need furhter assistance.
Thanks for using FixYa
Mar 26, 2010 | WiFlyer - Portable, shareable WiFi base...
I want to secure my wireless broadband router..how can i secure it?
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Mar 03, 2010 | Linksys Wireless-G Broadband Router
Need to rename my router because changed security code I pod or lap top wants look for the old code under the routers current name.
ok use the software you use to change the security code and where it says network name click on it, it should highlight then just type over it.
Feb 09, 2010 | Linksys Wireless-G Broadband Router
I HAVE AN OLDER TRUEMOBIL 2300 WIRELESS ROUTER WERE ARE THE KEY CODES TO MAKE IT SECURE OR DO I ENTER MY OWN AT RANDOM?
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Thanks for using FixYa.
Dec 22, 2009 | Dell TrueMobile 2300 Wireless Broadband...
MICROSOFT WIRELESS ROUTER
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway(default gateway should look like this 192.168.2.1)now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is blank and password is admin (this is generic to all the microsoft routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a microsoft router page,in that page you will see an option which says wireless click on wireless and then under wirless you will have the wireless security,now you need to enable the security adn choose the type of secuirty type and save the settings once you do that you wireless connection should be setup with a security code...
PS:when you make your wireless network secured make sure that the computer is connected wired to the rotuer..
vedhick
Feb 20, 2009 | Microsoft Broadband Networking MN-500...
NetGear WGR614 Wireless Router Logo
96 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
