Question about HP LaserJet 3055 All-In-One Printer
.a query about installation?
Pl tell me something about the procedure of the call transfering tothe fax machine after two ring.,
  • 24 Answers
Hi just press the menu button of the printer and go fax settings there is a option answer ring set as ur requirement.
Posted on Mar 02, 2008
I have Panasonic kx-Fl 402 FAX machine. The port of fax and telephone line is OK. But there is NO ringing tone in the FAX. Please give me solution.
Dear
Pl.sett the ring pattern and ring volume for the fax machine. Pl. follow the link for the setting detail..
ftp://ftp.panasonic.com/faxmachine/kxfl421/kx-fl421_om.pdf
Thanks.
Mar 06, 2015 | Panasonic Office Equipment & Supplies
Want to change the ring setting to 6 rings before i goes to fax mode how to do it
See the "Changing the ring setting of the telephone answering machine" section on page 60 of this manual.
Jan 31, 2013 | Panasonic KX-FG6550 Plain Paper Thermal...
I have muratec F65, i want to adjust the tx/rx baud rate to 9600, but in the setting i found nothing, pl guide ahmad dubai
Adjusting the Baud rate is something that a Serviceman has to do....there is no need tho'...your machine is smart enough that when "modem training" takes place each time you place a call..both the fax machines "talk" to each other and figure out how fast or slow they have to work depending on each of the fax machines and the condition of the line in between. They will slow down "if necessary" all by themselves.
Oct 29, 2010 | Muratec F65 Plain Paper Thermal transfer...
Peoplel are sending me very imp. faxes and idk how to recive it..
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
Oct 04, 2009 | Canon MX310 Office All-In-One Printer
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
# of rings before answering
Check to make sure you do not have distinctive ring option turned on.
Feb 05, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Hp printer 1020
Hello FixYa User,
If you are using thermal paper, Turn the roll upside down (I had the same problem).
If you don't use thermal paper please ring HP on 1 300 888 423 they will tell you whats wrong for free, If the Facsimale is faulty and is under warreanty they will fix it.
Hope this helps!
Sep 15, 2006 | HP 1020 Plain Paper Thermal transfer Fax
HP LaserJet 3055 All-In-One Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
