Question about Blaupunkt DX-V GPS Receiver
Travel pilot E2 - unable to calibrate, either auto or manual.
I ahve had installed a new Travel Pilot E2. When I read the manual about calibrating it states the ignition must be off, switch on the set, press menu for 2 seconds plus, scroll to installation,ok, auto calibration, ok, drive for 3-10 miles and the percentage strip will eventually rise to 100%.
When I start the engine the screen claers and then comes back on with either radio or cd readout. I have tried setting up with the engine already running but after several miles it still shows 0%. Hav ealso tried manual calibration with the same results.
Blaupunkt told me to ignore the instruction manual where it clearly says set up without ignition, then start the engine ??
I don't have the speed pulse connected because I was told this wasn't necessary, could this be the problem?
  • Thirams May 16, 2009
    I have the same problem with my DX-V after replacing the car battery, the navigationsystem have lost the calibration. I have tried to use the automatic calibration as well as the manuel but nothing seems to work.
    If anybody know how to solve the calibrationsproblem, please let me know.
You must have the speedpulse conected with out it conected it will not callabrate
Posted on Aug 10, 2009
How do turn on the pilot to the oven? and how do I know its calibrated correctly? I have an LP version
On this unit the pilot lights it's self when the oven needs heat as for checking the oven you can put a temp probe over the exhaust and it should read around 20'c less that it is set to
Oct 04, 2010 | Imperial IR-6-C Elite Gas Kitchen Range
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
I'm in Belgium fan of fsx with window 7 64bits with saitek x52 pilot 6.0.4.1(HID-USB) All the bitton are working except one : the twit (rudder). It makes a mouvement (kind of vibrations) around the the...
You should set this axis up first as a rudder in FSX settings, then calibrate it. Make sure you hav the latest drivers for it too. Make sure that Auto-rudder check box is unticked. I hope this helps, good luck
May 08, 2010 | Saitek X52 Flight Control System
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Oct 06, 2009 | Nautilus Exercise & Fitness
Main burner too hot & 2nd burner pilot won't
Set t/stat to 250 degrees. If it does not shut off after about 5 minutes, replace t/stat.If shuts off, must be calibrated Pilot may be dirty, flame weak. If flame strong, replace thermopile(pilot generator). If weak, must remove and clean pilot orifice inside pilot.
Aug 29, 2009 | Keating Kitchen Appliances - Others
Oven keeps randomly shutting off. wont stay lit
pilot sensing device should have tip in the flame only, calibration of thermostat possible with butto removed, if standing pilot is going out possible thermocouple or pilot generator or gas valve bad! could also be a safety hi limit opening in control circuit if has one?
Aug 23, 2009 | Vulcan Ovens
T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Raymarine C 80 Head up problem
I calibrated my autopilot compass and that resolved the problem. My auto pilot compass was about 100 deg out.
Once i did this the problem was resolved.
Aug 26, 2008 | Raymarine C80 GPS Receiver
Runs but does not heat
Try removing the jets and clean them out. the pilot may be off center and in need of calibration.
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
Blaupunkt DX-V GPS Receiver Logo
788 people viewed this question
Top Blaupunkt GPS Experts
Martin Murray
xxxxxx xxx
Are you a Blaupunkt GPS Expert? Answer questions, earn points and help others
