Question about Kogi l4ax 14.1" Flat Panel LCD Monitor
Monitor screen is into four different places change video card and still does same thing
  • 180 Answers
Try checking lcd logic board.
Posted on Apr 22, 2008
My computer scrambles data?
Either your monitor or video card is going bad. Try a different monitor to isolate the problem. If you attach a different monitor and it does the same thing, then your video card is going bad. if you attach a different monitor and it does not have the problem, then your monitor is going bad.
Apr 07, 2012 | HP Computers & Internet
When i switch on the computer, the only thing that appears on the screen is "power save mode on". i have checked all the cables, i changed monitors, but no solution for the moment thanks for...
Im assuming the monitor worked OK until now. The two things I can think of is, First is the cable from the monitor to the computer is either not connected tight either on the monitor side or the computer. The second thing I can think of is a bad video card. I think the monitor is ok because your getting the power save mode on the screen.
I hope this helps you out, if it does please leave me some positive feedback.
Apr 04, 2011 | LG Flatron L1710S 17" LCD Monitor
Getting black horizontal lines across the screen. It started off as an intermittent problem, now occurring more often. I changed the video card and the power supply tests fine and I changed the refresh...
I would test the cable, use it on a different monitor or try a different cable. That is the only other thing to check, otherwise it definitely is the monitor.
Apr 07, 2010 | NEC AccuSync 700 (White) 17 in.CRT...
Screen is blurred. removed and attached a different monitor and is the same. It is not the monitor
There are four things you can check for a blurred monitor:
1. The monitor itself (you eliminated that one) 2. The monitor cable and it's connection (make sure the cable is connected well on both ends, replace it if you can) 3. Video card driver (new drivers are free from the manufacturer's website 4. Video card (the card itself might be bad)
Jan 22, 2010 | Compaq Computers & Internet
Screen displays in four sections even at bios
What do you mean by four sections. Can you see everything on the screen but just in different colors. If so then it is the video card. Another thing you may want to try is to reseat the LCD cable on the system.
Nov 25, 2009 | Dell Inspiron B130 Notebook
New monitor flickers when hooked to computer
Hi!
There's a few usual culprits for this problem.
  1. Check the cable. Swap to a different cable if possible to rule that out.
  2. Check the refresh rate of your monitor. Most monitors have options for this via a Menu button on the screen itself.
    If you find it, change it to 60 hertz
  3. Check the refresh rate of the monitor from your operating system/video card's software.
    In Windows, right click on the desktop, click Properties, then the Settings tab, then Advanced. Change it to 60 hertz if it's anything different.
It could be faulty but hopefully not.
Couple of things there to try...let us know how you go
Nov 21, 2009 | Samsung Computers & Internet
My packard bell lcd monitor shows orange then sometimes green light but has totally black screen. If power supply giving insufficient voltage would this cause above problem?
> insufficient voltage cause ?
Well, anything is possible, but other things are more likely:
1. loose connections of the "data" cable between the monitor and the computer's video-card;
2. an electrical "short" in the data-cable;
3. a "dying" video-card.
So, try the "free" stuff first:
Check the connections.
Try a different cable.
Try connecting the monitor to a different computer (laptop?).
Try connecting a different monitor to your computer's video-card.
Then, consider buying & installing a new video-card.
Nov 18, 2009 | HP Computers & Internet
Monitor wont turn on, light flashing
A number of things can cause this. Incorrect BIOS settings, cable problems, a faulty monitor or problems with your video card.
1) If you can change the monitor cable - do so
If it worked, great else - carry on....
2) If you have two monitor inputs on your computer swap the connection to another input, only if it is on another card. If it worked great, else carry on.....
3) Try a different monitor to see if the same thing occurrs... if it does then it is either video card or BIOS
4) Reboot your computer and watch the screen - it will tell you to pres a key to enter BIOS or setup - do so.
Switch of cacheing of Video RAM
and Disable ACPI settings - all power and green energy settings. If that does not do the trick then it is most likely your video card - or your monitor... borrow a monitor and video card for ten minutes and you will find out which is the problem
Oct 05, 2009 | Computers & Internet
Screen goes pink and green starting with a few pixels
Best thing to do, try a different known working monitor to hook up to the computer. If the screen works and doesn't change colors then you know its the original monitor that is bad.
If you hook up the known working monitor and the same problem happens then you know its the video card that is bad and the video card would have to be replaced.
Aug 23, 2009 | ASUS VW222U Monitor
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Kogi l4ax 14.1" Flat Panel LCD Monitor Logo
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
