Question about Technics SB-AS60 Speaker
TECHNICS SUBWOOFER SB-AS60
I have the above named subwoofer. The volume control is bad. I have contacted panasonic. I gave them the part # to the volume control. They said somebody was going to contact me but of-no-avail.
What is the part # of the board that the volume control is attached to?
Would it be a good advise to change this board or just deal with the volume control???
All good wishes for Peace in your days ahead.
FA
  • 85 Answers
Hi, i will sugest you , just clean the volume control with lighter fluid,, then let it dry,, its just a dirt,, try it,, ,, coz iv done it many times. . . . god bless .. gud luck
Posted on Mar 01, 2008
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Oct 01, 2010 | Panasonic SC-HT690 System
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Panasonic dvd player for subwoofer
I have a SA-HT 690 system with a bad SB-WA342 sub. I can sell you my player or buy your sub.
Oct 29, 2008 | Panasonic SC-HT730 System
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
703 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
