Question about Microsoft Windows XP Professional for PC
Not booting computer not booting when powered up Saafe mode reboot windows key...everything
  • 1 more comment
  • 1jerseygirl Apr 15, 2008
    Same issue. Windows will not boot up in any mode. I see the Microsoft logo then a blue screen that appears real fast and shuts down the computer then automatically tries to reboot again.
  • sudhi_s73 Aug 26, 2008
    The system starts booting. While I'm about to get the windows prompt the system hangs. The booting is halted there and I need to restart the system by switching off. So I have a problem while booting and this happens every alternate time.
  • Anonymous Dec 02, 2008
    When I turn my computer on it makes several beeping sounds, but the OS doesn't show up on the monitor.
    Problem Solver:
  • 14 Answers
I had that problem. I know what you could try. Before turning on your computer, unplug any USB devices plugged in. Turn on the computer and wait. If it gets passed the part where it didn't work it's fixed. Another thing you could try is this. (You must have at least two computers or a laptop) Get a floppy disc or if you have burning software use that. Make a bootable disc or in the case that you are using a floppy disc go into format and format as bootable disc. By the way, you must have the same OS as the other computer. When that is done put the disc into the suffering computer and go into where you find Safe Mode and boot from the CD. (or floppy) Now try doing whatever comes on-screen. Another thing is if you have a Norton antivirus (ect.) then put the CD in and boot from that. Hope it helps
Posted on May 30, 2008
Please post full problem....
what happens after pressing the power button .
is it loading windows but restarts before opening it ?
Posted on Mar 01, 2008
HP 9620us no DVD/cd missing?
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct Function key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 13, 2012 | Computers & Internet
Tip
Reboot and run in safe mode in windows 7,Vista,XP or 2000
Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system.
1.) Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows OS Operating System before Windows Vista, or select the right arrow in Vista. Select the "Restart" option
2.) Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer
3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on.
4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Note: If you have more than one partition installed, you may need to select an operating system and press Enter before entering Safe Mode.
Turn on or restart your computer.
After the memory test, the words "Starting Windows" will appear on a black background. When this happens, press and hold the F8 key. This will present a screen with the following options to choose from. The exact moment that F8 is pressed will determine the contents of the list, and the list may vary from computer to computer. For example, your computer may not do a memory test or it may have a SCSI BIOS to load in addition to the motherboard's BIOS. If you have trouble getting the list below to appear, restart the computer and then press F8 repeatedly while the computer is starting.
Safe Mode: Boots Windows with only the basic drivers needed to load the operating system. Uses basic drivers for mouse, keyboard, display (VGA), mass storage, and default system services and drivers, with no network components. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Networking: Loads the Safe Mode configuration, but also enables network devices and services. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder.Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
Enable Boot Logging: Boots Windows with all of the normal files and drivers, but writes their status to a log file at each step. In Windows 2000, this log file is located in the Windows 2000 folder and is named ntbtlog.txt.
Enable VGA Mode: Boots Windows using a plain VGA 16-color 640x480 display driver for the highest level of compatibility with video cards. In Windows 7 and Vista, this mode is called Enable Low-Resolution Video. It is otherwise identical.
Last Known Good Configuration: Boots Windows using the last registry configuration that is known to work. This is a way of undoing problems created by installing incorrect drivers or possibly by registry corruption. It will not, however, fix problems caused by corrupted or missing files.
Use the arrow keys to move up or down this menu to make your selection, and then press Enter. If you need to update software or access the Internet while in Safe Mode, select "Safe Mode with Networking".
on Sep 15, 2010 | Computers & Internet
Media test failure message. Reboot and Select proper boot device
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
How do i reboot my computer my self.
Click the "Start" button from the taskbar. Select the "Turn off computer" option if you are running a Windows operating system before Windows Vista, or select the right arrow in Vista. Select the "Restart" option. 2.)Press and hold the Ctrl+Alt+Del keys simultaneously. Do it again. This will reboot the computer. 3.) Shut down the computer. Sometimes the computer will not respond to a reboot. Maybe the keys are temporarily disabled or the system has chosen to completely ignore you. In these rare cases, it may be better to shut the computer off using the power button. If you do shut off the computer, press and hold the power button for 3 to 5 seconds. Then be sure to wait a minimum of 45 seconds before turning it back on. This allows the capacitors in the computer time to discharge, which allows the memory (not the hard drive) to do a full dump of data. This allows a cleaner restart when you turn the computer back on. 4.)Disconnect the power cord. Do this as a last resort. Unsaved data may not be retrievable with this option, but sometimes it is the only option. Reconnect the power cord. Turn the computer on. else Insert the CD then reboot. While the system is booting, hit the F12 key to access the boot menu (this could be a different key depending on your system. If you have a problem with your hardware configuration or your computer's display drivers that prevents Windows from loading normally, you may be able to resolve the problem by booting into Safe Mode and changing the relevant settings. To enter Safe Mode in Windows 7, Vista, XP, or 2000:
Safe Mode with Command Prompt: Loads Windows in Safe Mode, and, after logging in, opens a command prompt instead of the normal desktop. In Windows 2000, a log file will be created to track the progress of the system boot, which is located in the Windows 2000 folder. Note: You should try booting to the command prompt only if you feel comfortable operating within the DOS environment.
All the Best!
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
F keys don't work on reboot. Work on Power on boot.
Turn your computer off.
Temporarily replace your keyboard/mouse with "generic" units.
Turn your computer on.
Check that the F-keys work.
Restart.
Now, do the F-keys work correctly?
Or, do you still get "keyboard failure"?
Jul 22, 2009 | Computers & Internet
Due to an incomplete download my screen is now blank.
I think it maybe something going on with the computer and not the monitor itself. As you turn on your computer keep pressing the F8 key and it will come to a boot menu. Choose safe mode and let it boot up. If you can get into safe mode then that means its something that is starting up that is affecting the operating system. If you get into safe mode, go into system restore and choose the last date that the computer was working correctly and then let the system reboot. Hopefully it will go back into windows all the way. If you can't get into safe mode then at that point try another known good working monitor on the computer and see if you can reboot into windows. If you can get into windows then the monitor is bad. If you still can't get into windows then that means your original monitor is good and that its a problem with the opeating system and that means you'll have to restore it back to factory defaults. Corrupt system files will cause windows not to boot up.
Jun 06, 2009 | ViewSonic VA1916w LCD Monitor
Windows xp starts twice and on second boot wont load user settings
Does it just sit at a blue screen? Is there only one user profile on this system? It could be a bad user profile in which case you can try logging on as administrator (if that isn't the user account issue). Try taking it into safe mode or last good known boot and see how far you get. If you recently installed something software or hardware then it could be related to the installation.
Apr 29, 2009 | HP Compaq Presario V2000 Notebook
It will boot up to the windows screen and freezes. There is no mouse control.
WIN XP ONLY!
Upon booting, beofre Windows Logo, press F5 key to get computer to boot into SAFE MODE/Administrator. See if you have mouse control under this mode. If yes, then there's a good chance that the mouse is OK .
once in SAFE MODE and are able to regain mouse, the chances are good that you can just restart the computer and everything will return to "normal".
Suggestion #1: reboot computer to NORMAL after having sucessful SAFE MODE mouse test.
Suggestion #2: see if you have a recovery point (system restore) before the mouse issue came about.
Jan 15, 2009 | Computers & Internet
My computer is in safe mode, dont know what to do to make it run normal again?
reboot the computer. Keep pressing F8 while it is rebooting to be presented with the advanced boot options menu. from here you can use the arrow keys to select start windows normally.
if you can't get the advanced boot options to come up by pressing F8, hold the power button while windows is booting to turn off the computer. Windows will sense that the PC did not boot properly and will display the advanced boot options menu. From here you can select to start windows normally.
Dec 08, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
103 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
