Question about Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu siemens 8830
Powers up, hard drive is fine, but no picture on screen at all. (Just Black). Attached an external screen, and it lit up but without a picture for a second, then blacked out again. Battery seems to be holding charge. CD drive sounds as if it loading normally, when disk in.
  • bonnielad Mar 09, 2008
    I have the same problem with my notebook and would welcome any solution..e disc and nothing the screen is blank..Power to notebook is fine.
    Tried restore disc and nothing happens
  • 520 Answers
Check to see if lid switch is functioning correctly if possible.
if **thing seen,** change ,inverter board needs replacing.
you've tried changing moniter so it isnt cable connections internal or external.
you're **t hearing any beeps so it isnt video,mem or hd.
Posted on Mar 10, 2008
Delete folder
Is the folder write protected ? If yes then unprotect it and try again.
Are there other files on the drive that you can delete ?
You can always reformat the drive and clean it that way but you will need to copy the other files from it before you want to do that.
Nov 08, 2013 | Fujitsu Siemens (MAN3184MCB) Hard Drive
I cant open my fujitsu siemens external hard drive, 3.5", storagebird, 35EV840. Tried uninstalling and reinstalling but still no luck. Not visible in 'My Computer'. Please help.
try this one
turn off computer and ext drive
keep drive plugged in but not powered
turn computer back on and stabilize
power up ext drive
does windows see it now?
May 31, 2012 | Fujitsu Computers & Internet
Where do i find the hard drive for the amilo li2727 to remove it?
before you start unplug and switch off!!
turn lap top upside down hinges to lit at the top
at the bottom left corner there is a 2 inch by 1 inch strip
remove the 2 screws
lift off plastic cover
pull plastic tab which is attached to the hard drive
the hard drive will slide out
Oct 24, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
My Fujitsu-Siemens Lifebook S7110 display going black time to time. It's coming back after restarting and it's working great with external monitor.
The display may be going black because of IC's getting heated up,contact ur Provider and get the screen replaced if using an external monitor is irritating
Dec 20, 2009 | Fujitsu Siemens LifeBook S7110 Notebook
Amillo pro 2010 screens gone black tried new inverter still no good cleaned ram no good the xp pro disc is off this laptop but got invalid message when reinstalled the screen went blank two days later cant...
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
Oct 02, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
Lifebook S7020 No backlight
Take the laptop to your nearest computer repair shop to have the inverter replaced.
It is situated underneath the LCD panel and converts DC electricity to AC to power the backlight of the LCD.
This shouldnt cost much to replace - around £40/£50
Aug 06, 2009 | Fujitsu Siemens Computers & Internet
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Fujitsu Siemens AMILO D-7830 Notebook Logo
322 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
