Question about NEC PlasmaSync 42XM2A 42 in. HDTV Television
Illegal Signal DVI/RB 3
Hi, I have a huge problem, when i want to use the DVI/RGB 3 input I only get "ILLEGAL SIGNAL" on the screen.
I hace the NEC 42XM2A plasma and ties to connect the Pace ViasatPlus HD that is HD ready. And uses there HDMI connectors.
Please help me, I really want the HD ready signal. With my last tv-box I used the rgb instead but this box only have HD Ready signal throw the HDMI.
Big thanks!
Micke
Stockholm
Sweden
  • Mikee66 Mar 01, 2008
    Hi, thanks for the answer, i didn't do the trick thow...
    I saw that I seem to only can choose between 1080A, 1080B & 1035I on my screen, not 1080I or 720P, could that be some problem?
    Micke
  • Mikee66 Mar 02, 2008
    Ah, I was afraid of that, and I know read that my DVI doesnt suport HDCP, so...
    On the other hand I have enjoyd HD-ready on my plasma before but trhrow the bnc contacts. The problem now is that my TV-box doesn't have other than HDMI and scart and the scart doesnt send HD. Is it possible to get BNC contacts from an HDMI cable?
    Micke
    Guru:
  • 1,894 Answers
See this link...here is the user manual....
Posted on Mar 01, 2008
  • 1,512 Answers
Have you checked menus and HDMI paths on the tv
  • 1 more comment
  • Graeme Ross
    Graeme Ross Mar 01, 2008
    You will need to reset signal paths for HDMI inputs from the setup menu
  • Graeme Ross
    in actual fact, your set predates true HD or even "full" HD ready. The HD settings it has are more for connecting a computer to the set, and only has Japanese HD ability(1035i) . So yes, I think you may need to upgrade you TV if you want "true" DigitalVideoBroadcast standard HD. Sorry man. That's what happens when a standard improves and surpasses old technology.
    regards
    Graeme
  • Graeme Ross
    Graeme Ross Mar 02, 2008
    2 different standards am afraid. You cant plug one to the other.
    A fixya rating would be great for my efforts to help you man, sorry that your fav old set isnt up to the job anymore... time to upgrade for that extra performance.Its well worth it man, for your watching pleasure that is ;)
    regards
    Graeme
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Thompson Wysius 42" plasma woes
did u try a different connector of cable?
Jun 12, 2008 | Thomson 30LCDB03B 30 in. HDTV
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Connecting dvd?
If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
Jul 01, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
DVI will not recognise now ?
Presumably, you're going directly from DVI port on computer to DVI port on Z2?. Here is a Q&A list based on all the possible sceanrios for this hook-up...
Q1: Is it DVI-D or DVI-I (with unencrypted DIGITAL output from graphics card)?
A1: Choose 'Input 2', then 'RGB(PC Digital)' on Z2.
Q2: Is it DVI-D or DVI-I (with HDCP-encrypted DIGITAL output from graphics card)?
A2: Choose 'Input 2', then 'RGB(AV HDCP)' on Z2.
Q3: Is it DVI-I or DVI-A (with ANALOGUE output from graphics card)?
A3: Choose 'Input 2', then select 'RGB(Analog)' on Z2.
After making sure the correct 'Input 2' is chosen to match the signal coming from the card's DVI port, make sure your card is outputting a suitable screen resolution that the PLV-Z2 can display correctly, e.g... 1280x720 (native, and preferable!); 640x480; 800x600; 1024x768 (choose this if you don't have 1280x720); 1280x1024, etc. Also, if you have multiple refresh rates availble for the resolutions, choose 60Hz.
You should end up with an image.
Sep 18, 2007 | Sanyo PLV-Z2 Multimedia Projector
NEC PlasmaSync 42XM2A 42 in. HDTV Television Logo
633 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
