Question about Electrolux EW1000i Front Load Washer
The drum will not spin round
Drum has been very noisy recently and has now stopped spinning altogether, it will not rotate at all
    Champion:
  • 249 Answers
Drum bearings are gone big job, may not be worth repairing.
Posted on Mar 01, 2008
Drum stopped spinning - Belt has come off - Wheel/drum stiff, no rotation. How to Fixya? Hotpoint IPX4 - 1669200001 - Grateful for any help / advice *********** - Cheers
You can do the repairs yourself, however be aware if the fact, the shroud surrounding the drum was stamped out from a sheet of metal and it has extremely SHARP edges that can slice your had or wrist wide open. Safety First. You must remove the rear panel and expose the back of the drum. Remove the spent belt and stretch a new one over the pulley wheels. Rest the drum shaft into the rotational collar on the back panel and fasten all screws tight in place.
Feb 05, 2018 | Dryers
Noisy machine AEG Lavamat 35600 Tumble Dryer
moter 1st i would say thx nick
Feb 10, 2008 | Dryers
Washing machine is now noisy when it spins it is a swan essentials
If you put your hand inside the drum and rotate the drum by hand does it rumble if it does it is your drum bearings
Nov 05, 2012 | Washing Machines
Washing machine drum does not rotate.
was the waser noisy before it stoped woeking if so it could be your drum bearing or somthing caught in the drum
Nov 10, 2011 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Electrolux EW1000i Front Load Washer Logo
199 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
