I had this same thing happen to me recently. Control board was burnt to a crisp. Had to replace the control board as well as the fuse. Good Luck. Just to mention--now my dishwasher is not working after two months of running. Took it apart and the actual control panel was damaged when the control board took a hit. The lights would go off and then on at times--now it is dead.
Sounds like the motor when ka-fooeey! Have a technician check the motor with a volt-ohm-meter to make sure that that's the problem.
I pulled the door and it looks like the Electronic control assembly is toast. One of the plugs is also fried. I will check on a replacement assembly and plug. Thank you. -Jeff
