Question about Samsung SyncMaster 540N 15" LCD Monitor
My samsung sm 540n screen problem
While i am running my comp for more than four hour or early i can find some grains in monitor screen can suggest me
    Problem Solver:
  • 5 Answers
Really more info is needed.. :)
What are you doing with your computer when the problem manifests itself?
What do you mean by grains?
Does the problem present itself consistently; for example only when playing games or watching video, or all of the time?
The culprit is either your monitor or your video card. Downloading the most up to date drivers for your motherboard and video adapter may help. Additionally, drivers may be available for your monitor. If you have a defective monitor then you may be able to return it to manufacturer if it is within warranty.
Posted on Mar 01, 2008
After changing 25v/320mfd no display power on
May I suggest that for around one hundred dollars you can get a samsung 22.5 in screen.
Terry
Apr 06, 2014 | Samsung SyncMaster 540N 15" LCD Monitor
I have Samsung 540n TFT monitor. It's color have brown shades when starting movies in movie player. please suggest. thanks
Samsung LCD have a Maximum of 3 to 5 color plan predesigned. To use them you need to click the required buttons in the bottom of the LCD. Select the one that fit best to you.
If you think nothing happening use manual.
Or try changing the video setting for your movie player.
Feb 28, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
My samsung syncmaster 540n lcd monitor remains black when i boot the system but the monitor is not switching on i.e the monitor screen appears black and no images are displayed. but the cpu is working...
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 01, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung SyncMaster 540N Monitor takes long time for the first time. Once it is up, if I turn it off, and on again, it comes up as usual.
sounds live you video drivers are not right. verify this is being used. download and run the application setup. it will only install if you have the right monitor
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=540N
above is drivers for the Samsung SyncMaster 540N
Aug 12, 2010 | Computers & Internet
My samsung 540n monitor wont display only white light, how to resolve it?
if only white display is appear on screen it's means the problem is in main pcb section. its may be a loose contacting of the flap beetween main pcb & lcd panel. plz check it. if the main pcb will defective then no way to repair and replace the pcb.
Mar 03, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Is there any display driver for synmaster 540n
http://www.samsung.com/it/function/search/resultList.do?searchWord=540n
Mar 05, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Problem with samsung syncmaster 540N 15"
To replace all Electrolatic capacitors in Power supply& drie Currected
check all connectors are properly connected r not
Sep 13, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Monitor gets fluctuations
Hi, I strongly suggest you get the customer services out again as quick as you can this has faulty screen. Don't let them fob you off tell them it's still under warranty since their engineer came out to fix it this sounds like a faulty printed circuit inside the monitor. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 11, 2017 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung SyncMaster 540N 15" LCD Monitor Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
