Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
My kingston usb flash disk undergoing write protected physicaly
Acording program test disk in partedmagic 2.1, my flash disk undergoing write protected physicaly. those writen that, i should remove jumper handle write protection.
where that jumper is?
  • 6 more comments
  • Anonymous May 05, 2008
    usb
  • gorio0002 Jun 25, 2008
    how i can remove my disk write protected??i can't use my kingstone flashdisk because of disk write protected...
  • Anonymous Jul 06, 2008
    my kingston usb is copy protected so cant delete or copy files to it
  • Anonymous Oct 09, 2008
    "The disk is write protected".what the solution.still same...
  • Anonymous Jan 06, 2009
    i cannot write on my disk flash
  • nhghu Feb 20, 2009
    error message is displayed "the disc
    write protected" when to format it and trying to add some data on the disc
  • kingsameer77 Apr 29, 2009
    in my usb 512 mb when we plugged in usb,it will give write protected error,and no data will save in usb,it is not also formatting
    thanks
  • Anonymous May 18, 2009
    I have the same problem
    President:
  • 1,257 Answers
Its not jumber ,its a looks like a switch..
First try to see is there any lock in your pen drive and see if its not locking it, you will see a switch which locks the pen drive at one side and unlocks it when you slide that switch to other side ,some drives comes with that option to protect it ..but if it is not
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 13, 2008
In my usb 4 GB when we plugged in usb,it will give write protected error,and no data will save in usb,it is not also formatting
Posted on Jan 27, 2011
I tried to reformat, format and deleting files. the messages is write protect
Solving this program will probably require the use of a special disk-formatting utility written specifically for Kingston USB flash drives. Your BEST option is to contact Kingston directly:
http://www.kingston.co,/support/default.asp
Answer the questions on that page and follow the prompts to get help from Kingston. They will know how to help you solve the problem at no cost. If all else fails, they will issue you an RMA number so you can return the drive in exchange for a new one. Kingston customer support is excellent, so contact the company at that URL and they will help you get your USB drive working again.
Apr 29, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
This Disk is write protected
Hi!
if you use Windows XP or earlier, then - right click on your flash drive, goto "properties" -> uncheck "read only" checkbox.
If you use Win 7 or Vista - then use administrator account to run format (shift+right click on program, choose "run as administrator" ). the easiest way in Win7/Vista to format your flash drive is: Start -> all programs -> Accessories -> shift+right click on command prompt -> "run as administrator" -> type fromat driver_letter /q /y and press enter (e.g. if your flash driver has letter z, then you need to type format z /q /y and press enter). This will quickly format your flash drive.
If you use Linux/Unix/MAC OS, then you can use GParted or following command in terminal:
1. su
2. Enter password when asked
3. fdisk /dev/your_flash_drive_name (e.g. dev/sda/)
mkfs -t vfat /dev/your_flash_drive_name
Hope that will help :)
Jul 02, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove write protection from a 4GB pqi USB flash drive?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
KINGSTON USB 2.0 4 GB IS WRITE PROTECT. I want to format it, but a write protect problem is generated in.
2. Format
Jan 05, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb flash drive is write protected how can i remove it
USB flash drives are made of a small amount of flash ram and usualy the size of a persons thumb.
the software that resides on them determins if the "disk volume" is write protected.
if a software program other than the native software that came with the drive has write protected "files" that exist on the drive you will need to find out the name of said program and follow the proceedures for changing the write protection of those files.
Loch Hiam
Sep 13, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
REMOVING WRITE PROTECTION FROM MY USB 2 FLASH DRIVE
Hi, I am having problem copying or deleting from my Kingston Flash USB 4 flash drive. suddenly I could not delete or even copy anything into the drive. It keeps on indicating your disk is write protected. I have not secured the disk with a password, even then I have this problem....
How can i recover in this problem.
Jul 04, 2008 | iLO (2 GB) MP3 Player
USB problem
I had the same kind of problem with my 32GB Transcend USB Flash drive. I tried all the things I found in the internet (Apacer software, Registry fixes, Kingston software, HP Flash Disk software, you name it!) but nothing worked. Always I got Write protected error. Finally I found the program called MiniRMATool which solved the problem. Search MiniRMATool_XP2K_v1.rar in Google, run it and then you will be able to format your drive.
Jun 20, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston flash disk physicaly write protected
Hi
In the side of the drive there is small white switch . slide the switch in the opposite side,then it will be ok
Jyo
Mar 01, 2008 | Kingston (SDCZ2-512-A10-KT)...
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
8,496 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
