Question about Acer Aspire 5600 Series 5630-6951 Laptop
Starting too late
Hi My Laptop takes nearly about 10 minutes to get started. I mean after switching on I can do anything only after 10 minutes.. and while closing it takes quite some time to shut down.. Is there anything that we can do to start and stop the system in short time without any side effects or problem to my system.
Thanx
Bala.J.
    Sergeant:
  • 406 Answers
Please let me know the operating system Which one you are using. Please install the antivirus update and run with latest database.
Please remove un-necessary temporary files by typing %temp%
in the start>run> type %temp%. press ok. a window opens in Xp. Delete all the contents of the file.
Increase the virtual memory to double the physical memory. Defragment the hard drive,.
Posted on Mar 01, 2008
  • 100 Answers
If ur laptop have Windows vista operating system then Minimum RAM require 1GB.Please check the RAM speed.If ur laptop already have 1GB Ram then u do it disk defragmentation.I will tell u the steps to defragmentation disk.
Click on start - Programs - Accessories - System tools - Disk defragmentation.There u select disk(Ex: C:\) and click on Defragment button.After all disk defragmentation completed ,u restart laptop and check it.
Thanks
  • 133 Answers
You could be facing several problems or one.
1. Check the amount of empty space u havein ur HD, u need to have enough space in ur harddisk at least 1GB if its less try to delete some files or uninstall some programs.
2. Run an virus scan, viruses normally delay the speed of the machine.
3. There are many programs opening at startup thus taking long to load all of them, u can also try to upgrade the memory.
    Genius:
  • 1,019 Answers
This Is A Problem For One Of Our Tech-Guys Here @ FIXYA.
May I Suggest Purchasing The $19.99 Premium Support Package.
Our Experts Will Solve Your Problem Within 1 Hour Guaranteed.
Mike @ Compurepair.
Thankyou For Using FIXYA.
Continuous beeping and laptop is not starting
find the memory and either swap it or take it out and put it back in again...
success
Jun 19, 2012 | Dell Inspiron Mini 10 Notebook
HP G71T-300 laptop Wireless Card Problems
try reseting the router your hooked up to.
Feb 28, 2012 | HP Computers & Internet
Hi, have a 1995 nissan maxima automatic, 160K miles, after starting and driving about 10 minutes the car stalls while driving, and will not start for 10-20 minutes, then starts, and does same thing again...
it could be an egnition module or somthing basic like fuel presure .. prob the pump .. but lots of things can make it do that .. u need a mechanic to look at it
Apr 11, 2011 | 1995 Nissan Maxima
Dell inspiron with Windows vista... freezes every 10 - 20 minutes. Whether I am running anything or not. The only way I can bring it back is through restart. Doesn't heat up as I can feel by touching the...
Hi
Most common cause of this problem is the Operating System (Vista) if its starting to crash or infected of a virus. Reinstalling the Vista should fix this problem but if the problem persists it only means that your Hard Drive are having bad sectors and needs to be replaced.Thanks
Feb 22, 2011 | Dell Inspiron 1525 Laptop
I have C1110 Lifebook. It switch on only when it cold, usually morning, it work for 3-5 minutes and switch off. After that it couldn,t to switch on. (The green light "power" light for 2-3 sec, on each...
Take the battery out and only hook up the AC Adapter. Now turn it on at different times and see if the laptop turns on continuosly. If it does start turning on like normal then that means the battery is shorting out the motherboard.
Also try hooking your laptop straight to a regular wall outlet. Sometimes going thru a surge protector or UPS backup can cause strange things to happen on computers or laptops.
If you have the same problem then that means the motherboard is starting to go bad and would need to be replaced. cause thats where the power connector goes thru.
Feb 09, 2010 | Fujitsu Siemens LifeBook C1110 Notebook
2001 Honda Accord EX starting problem
The source of the problem seem to me it is an electrical problem,in this case you have to diagnose the ecu.
Nov 29, 2009 | 2001 Honda Accord
Ford f350 problem see details for summary thanks
gas pedal is a cable check near throttle body
there could be a fuse for the door locks or its the switch or actuator not related to the gas pedal
with the hissing sound
What i have encountered while doing compression checks while engine cranking and there is a hissing noise from exhaust it means there is a exhaust valve not seating properly or the valve seal is going bad.
Jan 29, 2009 | 1991 Ford F350
Sound and late starting problem in dell leaptop
Click "Start" > Click "Run" > type "msconfig" > click "Ok" > click tab "Startup" > Click "Disable All" > click "OK" > Restart system - should take care of the slow performance of laptop.
Jan 11, 2009 | Dell Latitude D600 Notebook
Late startup problem
there is some kind of conflict hdd and dvd, check there jumpers master/slave, if u could not do this consult a technician.
Nov 09, 2008 | Computers & Internet
Internal wireless card sudden error code 10
M200? Is this a Toshiba laptop? Error Code 10 can mean many things, but the first thing I would try is a Driver Upgrade. Reliable Drivers can usually be found at the manufacturer's website.
Dec 23, 2007 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
