Question about Microsoft Xbox 360 Console
Controller/Memory Card My 360 had three red lights flash that stopped after the console had been rebooted.But now it won't recognise my wireless controller, wireless internet conector or memory card. When i try to reconnect the controller after the lights have spun all the lights on the controller continue to flash. Please help.
  • r8ers81 Mar 02, 2008
    You need to return to xbox. They extended the warranty for this problem. But do'nt settle for a refurbished unit.
  • 52 Answers
My recommendation is to return the unit, but there is a popular way that does in fact work. I tried it and my xbox lasted 4 week longer. Basically, wrap it in 2 towels, turn it on and leave it for 30 mins, come back , unwrap and reboot xbox.
Posted on Mar 17, 2008
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Xbox 360 wireless controller won't connect to console
try getting a play and charge kit thats what i had to do
Nov 12, 2012 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Wireless Controller When I
If the battery has run flat you may need to pair the controller to the Xbox, Switch on your Xbox and press the small button to the right of the memory card slots, the four green lights will start to flash. Now press the small button that is next to the socket on the front of the controller.
Dec 19, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox 360 wireless adapter 1 red flash of light
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
Jun 09, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 Console: my xboxs 360 has three red lights flashing...
Hi Sir
Please Rate
May 17, 2010 | Microsoft Xbox 360 Console
Controller will not connect to game
To connect a controller to Xbox 360 console:
Wired Controller:
1) Simply plug in the controller into one of the three USB ports avaiable on the system. Two of which are on the front of the console( next to the power button, there is a small door, it is marked by two dots on top, open it and you will find the two USB ports, the third USB port is on the back of the system)
Wireless Controller:
1)Press and hold the Xbox guide button until the controller turns on.
2) Make sure that the console is on, then press and release the connect button on the console( the button next to the memory card slots)
3) Press and release the connect button on the Xbox wireless controller, if connected the ring of lights on the controller will stop blinking, one of which will now be constantly lit, The same will occur on the ring of lights on the console itself
Mar 16, 2009 | Microsoft Xbox 360 Console
Wireless controller wil not sync with xbox 360
turn on the console. let it start up all the way. turn on the controller. on the console to the right side of the two memory card slots is a little button. press and hold it til the green lights start flashing around the power button. there is a little button on top of the controller. when the lights around the power button are flashing, press and hold the button on the top of the controller til the lights around the center button start flashing and then it should sync together
Feb 18, 2009 | Microsoft Xbox 360 Wireless Controller
Wireless controller flashing green light but wont detect xbox360?
Have you tried resyncing your xbox and controllers? On the controller, press the little circle button on the top of the controller, between the bumpers. On the 360, there's a small circle button, about half inch wide, next to the memory card ports. Press that as well.
Jan 05, 2009 | Microsoft Xbox 360 Console
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Console Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
