SOURCE: my turtle beach x1 headset
Do you have your play n' charge kit plugged in? if so, then thats what is causing the buzzing sound
SOURCE: my turtle beach x1 mic doesnt work when i speak
What happens if you try using your X1 with a PC? The X1's green plug goes to the green Line Out (or Front) jack on your PC, while the X1's pink plug goes to the pink Microphone jack on your PC. If the X1 mic works with your PC, then the problem is the chat/controller cable and replacing it should fix the problem. If the mic doesn't work, then the headset will need to be replaced. Turtle Beach should be able to do that for you...
SOURCE: i cant hear anyone whilst ive got turtle beach x1
You probably kinked your controller cable. That will cause the mic to malfunction. You should purchase a new controller cable on TurtleBeach's website. They are only $4.95http://www.turtlebeach.com/products/efx1a/replacementparts.aspx
SOURCE: My turtle beach x1 wont turn on?
The green light (or red if it's muted) should glow on when you plug in the USB. If it doesn't, it means there's a problem with the power feed to your X1 and you should contact Turtle Beach tech support to get it fixed.
