Question about JVC KT-PK2000 SIRIUS Radio Receiver with Car Kit
Problem getting the radio to work after changing battery in car :-(
I just changed the battery in my car....and now I need to reset my radio with a pin number...nissan have given me the number...but unfortunately I cant enter it as it's showing an "err" (error) on the lcd screen ...they told me to leave the car running for an hour or so and it would change back to "code" on the screen then I can input the pin number...but I left the car running for 2.5 hours and it DIDN'T change back :( any help would be appreciated
the radio is the one that came with the car no bran model...
Michael
Usually only the radio needs to be powered up...NOT the engine running . Be sure all accessories are off so as to not run battery down. You might try disconnecting battery again & hold positive connection to ground for 30 seconds .
Posted on Apr 25, 2008
Need the radio code to reset after battery was disconnected.
Afraid there is no radio code as such....the Saab headunit is paired to the car with Saab Tech 2 software.
A dead battery swap shouldnt lose the radio if it was working before you changed the battery.
Have you checked the fuse for the radio?
You should also post on Saabcentral
Jan 14, 2016 | Saab 95 Cars & Trucks
Reset code mitsubishi car radio
Try using this code 8201 and when all four digits are displayed push either the tape or cd button and that should be it..
Hope that helps.........
Sep 12, 2008 | 1997 Mitsubishi Montero
Do I need to reset anything after I changed my battery in my 2005 Pacifica
probably --- if the car is not performing as new have the ECM reset using the scan tool
you may need a radio code to get the wireless to work
Dec 23, 2015 | Cars & Trucks
The radio won't work. It is currently on cd mode. When I put the radio on it starts playing the same cd that has been in for a week now. All the buttons dont work. I can't change the mode.
Sound as if there is an internal problem with the system. Will the CD eject when commanded? If not, try to remove it manually with a pair of tweezers or something of the sort to see if it will come back on line. You can also disconnect the battery for a few minutes to erase the units memory ( you may require a code if it has a theft feature ) to see if it will start working again. If nothing gets better, suspect an internal unit issue
Nov 29, 2015 | 2006 Ford Focus
Radio will not power up.
there is it should be located on the back of radio itself. if that doesn't work you may need to check your fuses
Aug 19, 2013 | 2005 Subaru Forester 2.5
Changed battery need codeto reset radio?
Hi:
You need to get your radio security code from your Honda dealership service department. this is an antitheft code, to keep crooks from reselling stolen radios, so if you go to the dealer, and provide the VIN number of your Honda, they should be able to help you out!
Sep 22, 2010 | 1998 Honda Accord
Look all i want is to get my radio going i had a compressor change battery was remove wat do i have to do to get this imfo.
Hi and thank you for using fixya:
I would like to address that removing your battery and connecting back on will not invalidate or make your radio go out of service. Removing your battery does resets your radio to factory settings but it should be working fine. Check for any cables or fuses that are gone.
Good luck
Jun 22, 2010 | Car Audio & Video
Hi. Need a code to reset radio after changing the battery. Thanks
you must pull radio and get serail # then go to dealer with some id and registration then they will give you the code #. hope this helps.
Jan 17, 2010 | 1997 Ford Explorer AWD
Changed car battery unable to reset radio code...Help!!
ALL at the same time, try again!
Good Luck...
Jun 14, 2009 | 2003 Suzuki Aerio
Saturn vue 2004 repalced battery
If it is like most Saturns if you had the radio or any eletrical equipment on when you changed the battery it blows the fuse. It will also blow the fuse to your turn signals or wipers if they are on.
Nov 15, 2008 | 2004 Saturn VUE
JVC KT-PK2000 SIRIUS Radio Receiver with Car Kit Logo
558 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
