Pc tooo slow
I have a toshiba l35-s1054 and for a few months now it is slow sometimes it takes a day to turn on. I already removed and reinstalled everything and no change what can I do please help me...
Hello there shemaine, try to replace memory ram with a new one and be sure to buy the same specification. good luck! i'm sure it will solve ur problem.
piping
Posted on Sep 16, 2008
    Genius:
  • 1,019 Answers
If you,d really Like This problem solved, I,d Suggest Getting Premium assistance For $19.99.
One of Our Experts At Fixya, will only more Than Happy To Assist You To Completion.
If You Free Post, You,ll Probably get not much response.
Or my Solution:- If your Computer Takes A day To Boot-Up.
Try Setting The Time And Day 24 Hours In Advance :)
Hope This Helps :) Mike @ Compurepair.
Posted on Mar 01, 2008
"how to clean & install toshiba satellite l35-s1054 win 7 "
Look in BIOS during reboot, make sure the hard drive is detected. Run hard drive test and memory test. Use BIOS feature to setup boot options and boot order, set all to default. Reboot.
Feb 10, 2013 | Toshiba Satellite L35-S1054 Laptop...
I replaced my screen on a toshiba L35 laptop and turned it on screen is black now comp is running . help please?
try first your laptop without using your laptop screen. remove laptop screen and testing display output from your CRT or LCD monitor. if display comes out, try to check your inverter.
Feb 04, 2011 | Toshiba Satellite L35-S2366 Notebook
Can't get into BIOS on my Toshiba Laptop
Hi
No manufacturers password that I have ever heard of but you can remove your keyboard and disconnect the mother board (BIOS) battery. Leave it disconnected for a few minutes. When reconnected the password should be gone. A few laptops actually have a jumper to do this.
Mar 29, 2010 | Toshiba Satellite L35-S2366 Notebook
Fixing DC Jack for Toshiba Satellite L35 cost how
I believe the L35 uses what is considered a satellite power jack which means the actual jack is not soldered to the motherboard but uses a cable and plug, therefore is the easiest of the power jack repairs. The cable can be found on ebay for around 30 bucks or less. I usually charge 50 bucks for the labor plus the part, the laptop has to be disassembled to complete the repair. Below is a link for disassembly if you want to use it as a reference and perfrom the work yourself.....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/taking-apart-laptop-1.htm
Jan 04, 2010 | Toshiba Satellite L35-S2366 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Toshiba A215 bios password
This is a known bug on some Toshiba lappies - and one of the reasons I updated my A215 BIOS 4 times in the last few months!
Not sure if this is what happened to you, but...
Applicable Models: Satellite A100-ST8211, A100-SP471, A100-ST1042, A100-ST1041, A105-S4001, A105-S4002, A105-S4004, A105-S4014, A105-S4051, A105-S4094, A105-S4144, A105-S4034, A105-S4054, A105-S4102, A105-S4124, A105-S4114, A105-S4132, A105-S4134, A105-S4064, A105-S4024, A105-S4211, A105-S4201, A105-S4092, A105-S4084, A105-S4184, A105-S4194, A105-S4174, A105-S4164, A105-S4154, A105-S4342, A105-S4284, A105-S4274, A105-S4254, A105-S4244, A105-S4214, A105-S4204, A105-S4104, A105-S4074, A105-S4547, A105-S4334, A105-S4304, A105-S4294, A105-S4364, A105-S4344, A105-S4021, A105-S4031, A105-S4012, A105-S4011, A105-S4397, A105-S4374, A105-S4384, A105-S4022, A110-ST1111, A130-ST1311, A130-ST1312, A130-ST1313, A135-S2246, A135-S2256, A135-S2266, A135-S4499, A135-S4498, A135-S4488, A135-S4478, A135-S4507, A135-S4487, A135-S4477, A135-S4467, A135-S4457, A135-S2396, A135-S2386, A135-S4637, A135-S4527, A135-S2356, A135-S2346, A135-S2336, A135-S2376, A135-S2326, A135-S4517, A135-S2306, A135-S4727, A135-S4677, A135-S4666, A135-S4656, A135-S2426, A135-S4447, A135-S4437, A135-S4427, A135-S4417, A135-S4407, A135-S2296, A135-S2286, A135-S2276, A200-ST2041, A200-ST2042, A205-S4617, A205-S4639, A205-S4618, A205-S4567, A205-S4577, A205-S4587, A205-S4597, A205-S4629, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S7468, A205-S7466, A205-S7464, A205-S4607, A205-S4578, A205-S4557, A205-S4537, A205-S4638, L35-SP1011, L35-S2194, L35-S2174, L35-S2161, L35-S2316, L35-S2366, L35-S2206, L35-S2171, L35-S1054, L35-S2151, M200-ST2001, M200-ST2002, M205-S3207, M205-S3217, P100-ST7111, P100-ST1071, P100-ST9612, P100-ST9412, P100-ST7211, P105-S921, P105-S6002, P105-S6014, P105-S6054, P105-S6034, P105-S9337, P105-S6227, P105-S6217, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6024, P105-S9312, P105-S6004, P105-S6012, P200-ST2071, P205-S6297, P205-S6298, P205-S6247, P205-S6287, P205-S6257, P205-S6267, P205-S6237
Tecra A7-S712, A7-S612, A7-ST7711, A7-ST7712, A7-ST5112
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 1.40. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
BTW, I've heard that this only happens when you boot up on battery power.
Maybe you can confirm this...
Aug 13, 2008 | Toshiba Satellite A215-S5822 Laptop
Toshiba Satellite L35 S1054 Laptop Pad Touch problem
Try toggling the touchpad enable/disable button -
Fn-F9 I think. There is a picture of the touchpad on one of the Fxx keys.
Dec 24, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
331 people viewed this question
Alun Cox
David Payne
David Payne
