Unplug the tv, take the back off,locate the G board, next look for D 6301,and D 6116,these are diodes,desolder them and replace them,if that didnot fix it,then change the switching regulator also,its also on G board..use a desoldering iron to remove parts, then wick wire to get the access solder off the pin holes to resolder parts.hope this helps.....
Which one is the g board?
http://www.agoraquest.com/viewtopic.php?...
This worked for me just re-soldering the 2 parts (not removing them, just resoldering each side).
I have access to purchasing the parts as I work at a company that builds circuit boards. I need the parts list for this TV so I can order the correct components for D6301 & D6116 as well as the switching regulator
