Question about Lite On LH-20A1H DVD RW Dual Layer Burner
Lite-on dvdrw LH-20A1H problem
I have installed a new lite-on dvdrw LH-20A1H drive which is having issues.
If I have been using either a CD or DVD and I eject the disc and insert a different disc it still shows the properties of the previous disc and will not display the contents of the new disc.
I would greatly appreciate any advice that I can get to resolve this problem.
Thanks& Regards
Andrew
  • Aussiepiper Mar 03, 2008
    Thanks pk86bhat for your help.
    Whenever I have changed discs I have closed the program that was using that drive i.e media player or ripping software etc.
    I have found that by restarting the PC it will show the new contents of the new disc.
    However this is somewhat of a nuisance each time you want to change a disc.
    It is also more of a problem if you are installing software from multiple discs such microsoft office etc, which works fine until you get instructions to insert disc 2 etc, and it still displays the contents of the first disc.
    This problem has only arisen since I installed my new drive.
    Any more help on this would be greatly appreciated.
    Regards
    Andrew
  • 75 Answers
Dont eject the cd when windows is still using the cd anyway ,like copying ,songs playing ,
easiest solution -restart the pc
i face the problem but it is once a time not repeated so ,restarting the pc.no more ideas
regarding
prasanna
Posted on Mar 01, 2008
My Lite-On DVDRW -LH-20A1L plays audio cd, reads date cd but does not play DVD movie's. Please Help?
Hi Mhlato,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not play a DVD, chances are your CD/DVD player needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Dec 27, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
I have the Lite On DVDRW LH-20A1H it shows the DVDs are full and will not record on them will play a dvd that I have previously recorded but shows all DVDs as full works fine with CDs. Recently had to...
Try to isolate the problem by using the drive with another computer. If its showing the same problem then your drive is probably busted. Also, try to change data sables, see if that will help. Have a good one.
May 14, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lite On LH-20A1H DVD RW burner refuses to recognize DL disks?
I have an LH-20A1S, & I am using Roxio Easy CD
Creator 6; Yes, I know there are newer versions, but they all ****! Anyway, it USED to work just fine in recognizing DL DVD's W/the updates from Roxio's site. & now there is no option there for this size (8.5)w/in the actual Creator prog. Is it the drive? This JUST started happening recently. Any clue if it IS the drive? & if so, any idea what caused this? I've always used Lite-On's & have NEVER had this sort of prob before! & of course it is out of warranty, & a discontinued model to boot! standar DVD drives are real cheap inprice these days, but STILL I do't wanna have to buy an new one if I can 'fix' it. BTW, I have updated the latest firmware for this drive from Lite-On's site too, & it didn't resolve this issue either!
__ERIC
Jan 31, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Won't reognize about half of my DVD Rs
The only thing that it might work if you use DVD-R some writers and home theather seem to not like DVD+R
Jan 08, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Software problem
Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
Sep 16, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
263 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
