Question about Microsoft Windows XP Home Edition
Not able to delete partition in hard drive
I have a very small hard disk which is of 6 GB in size.The problem is that because of viruses and other problems i had to reinstall windows XP professional several times.Now the total available size on my disk is 800MB.
While installing windows when i am trying to delete the partitioned space it says it can not be deleted because the set up files are installed on it.The problem is that my computer does not support bootable cd.Is there any way i can delete all the unused partitions on my disk and get some space on my hard disk?
Thanks
Michael day
Step1:
 Start our system then press delete button with the start of system.
Step2:
you got a blue screen(BIOS) ,chose advance feature then,there will be something releted to BOOT device or
there will be option First boot,Second boot.....
 then chose First boot pres enter ,and chose youe CD-ROM as first boot then,Press F10(save and Exit)
noe the sys tem will Restart.
Step3:
Put the booteble cd.
Delete all unessesary partation .(all the options you can see on the instalation window also).
And make a new partation,and Load new XP in your System.
i hope it will solve your problem.
Posted on Jul 23, 2009
    Scholar:
  • 117 Answers
This will be in a few steps..pleas follow carefully.
l
To delete a partition or logical drive • Using the Windows interface if(typeof(IsPrinterFriendly) != "undefined") { var l = "#BKMK_WINUI"; var nl; var c = l.charAt(0); var o = document.getElementById("EO"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; }
Using a command line if(typeof(IsPrinterFriendly) != "undefined") { var l = "#BKMK_CMD"; var nl; var c = l.charAt(0); var o = document.getElementById("EU"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; }
Using the Windows interface 1.
Open Computer Management (Local).
2.
In the console tree, click Computer Management (Local), click Storage, and then click Disk Management.
3.
Right-click the partition, logical drive, or basic volume you want to delete, and then click Delete Partition.
If the menu item reads Delete Volume instead of Delete Partition, the volume is a dynamic volume. For instructions on how to delete a dynamic volume, see Related Topics.
Caution
• When you delete a partition, all data on that deleted partition or logical drive is lost.
• You cannot recover deleted partitions or logical drives.
Notes
• To perform this procedure on a local computer, you must be a member of the Backup Operators group or Administrators group on the local computer, or you must have been delegated the appropriate authority. To perform this procedure remotely, you must be a member of the Backup Operators group or Administrators group on the remote computer. If the computer is joined to a domain, members of the Domain Admins group might be able to perform this procedure. As a security best practice, consider using Run as to perform this procedure. For more information, see Default local groups if(typeof(IsPrinterFriendly) != "undefined") { var l = "/WindowsServer/en/library/f6e01e51-14ea-48f4-97fc-5288a9a4a9b11033.mspx"; var nl; var c = l.charAt(0); var o = document.getElementById("EKC"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; } , Default groups if(typeof(IsPrinterFriendly) != "undefined") { var l = "/WindowsServer/en/library/1631acad-ef34-4f77-9c2e-94a62f8846cf1033.mspx"; var nl; var c = l.charAt(0); var o = document.getElementById("EPC"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; } , and Using Run as if(typeof(IsPrinterFriendly) != "undefined") { var l = "/WindowsServer/en/library/8782f8ab-9538-4111-8a68-7bfd130c21c01033.mspx"; var nl; var c = l.charAt(0); var o = document.getElementById("EUC"); switch (c){ case "/": nl=(" [http://" + document.domain + l + "]"); break case "#": nl=(""); break default: nl=" [" + l + "]" } if(o != null) o.innerHTML = nl; } .
• To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
• You cannot delete the system volume, boot volume, or any volume that contains the active paging file or crash dump (memory dump), or OEM partition.
• You cannot delete an extended partition unless the extended partition is empty.
All the logical drives in an extended partition be deleted before you can delete the extended partition.
Posted on Mar 01, 2008
  • Terry Lynn Deschamps
    Terry Lynn Deschamps Mar 01, 2008
    Notes
    the Backup Operators group, Administrators group, or you must have been
    delegated the appropriate authority. If the computer is joined to a
    var nl;
    var o = document.getElementById("EGH");
    switch (c){
    case "/":
    break
    case "#":
    nl=("");
    break
    default:
    nl=" [" + l + "]"
    , Default groups
    var nl;
    var o = document.getElementById("ELH");
    switch (c){
    case "/":
    break
    case "#":
    nl=("");
    break
    default:
    nl=" [" + l + "]"
    , and Using Run as
    var nl;
    var o = document.getElementById("EQH");
    switch (c){
    case "/":
    break
    case "#":
    nl=("");
    break
    default:
    nl=" [" + l + "]"
    To open a command prompt, click Start, point to All programs, point to Accessories, and then click Command prompt.
    You
    partition.
    You cannot delete partitions on removable media using DiskPart.
    For more information about DiskPart, see Related Topics.
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
120 gb hdd shows only 3.99gb
Your hard drive maybe partitioned with a small partition and the remainder of the hard drive may not be partitioned at all and therefore not accessable until a new partition has been created and formatted.
You may wish to delete the existion and then create one partition of maximum size.
NOTE - backup your data because when you delete the existing partition and create a new partition and format this partition you will lose your data.
Feb 11, 2012 | Computers & Internet
I need to format my usb key maxell 8giga. i need a low level program. could you help me? thanks!
try using the diskpart application which is in windows
type
list disk[enter]
which should then provide you with something like this DISKPART> list disk
Disk ### Status Size Free Dyn Gpt -------- ---------- ------- ------- --- --- Disk 0 Online 466 GB 8033 KB Disk 1 Online 4 GB 111 KB
your pen sticks size should reflect the actual size of penstick to help you identify it, in this case above the 4 GB one so its disk 1 ensure you do you may delete the hdd if not careful
then type select disk 1 then clean then creat partition primary then select partition 1 then format
May 11, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
Im copying a game that is 5 Gb and my free space is 160Gb why does it say that the "there is no disk space" is there anything i could do?
1.plz check your hardisk about any virus..
scan your hardisk a good antivirus
and check your partition type FAT or NTFS, FAT32 only support maximum file size 3gb
if FAT32 please convert as NTFS.
please letme know this helpful
Feb 01, 2011 | Western Digital WD Passport 250GB Portable...
Wd drive PATA wdc-wd2000 jb - 00fua0 should be a 200 gb drive. said was running out of space and when checked found drive was only reporting it's size as 31.49gb. have tried everything I can think of to...
Check the hard drive for partitions, it could have several partitions, but only the first partition has been formatted.
Go to Control Panel - Administrative Tools - Computer Management - click on Disk Management and look at the Western Digital it could be Disk 1.
If you see unallocated partition, you can create and format this partition.
OR
You can delete the existing partition and create a single large partition and then format this partition.
NOTE - this process will delete the existing data on the hard drive.
Dec 16, 2010 | Western Digital (WD2000BB) 200 GB Hard...
300 gb hard drive but only 32 gb is visible
Check your jumper settings on the drive it sounds like youve got the jumper over the 32gig limit pins.....cheers from Scott and plz vote
Oct 23, 2010 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Recycler folder virus
You don't have a virus, you have the folders without an executeable link. Use windows explorer to delete the files you want to get rid of.
Sep 07, 2009 | Microsoft Windows XP Professional With...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Total size is not 80 GB IDE Hard Drive
Two possible solutions but both calls for another software/utility.
1. Use FDISK but you should be booting and running in DOS mode;
2. the other is Partition Magic which runs under Windows environment.
The idea is to delete the existing partition (that shows only 31.50Gb) and thereafter re-partition to the full capacity of the drive. of course doing so would erase the contents. Further, a format after the re-partition is required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 19, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Microsoft Windows XP Home Edition Logo
986 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
