Question about Ricoh Aficio 450 Copier
Gestetner-2412Z copier-error code UF
My copier displays UF code immediately when I turn on the power. How can I resolve this error code? Is there a way I can reset it? Thank you so much.
  • 87 Answers
The large tray on the right is where the jam is. Slide the lever to the right and disconnect it from the machine. Open the cover as if you where filling it with paper. Look inside for and half sheets of paper, or possibly misloaded paper. If everything is ok, the front cover by the lever needs to come off. There are 2 screws on the bottom of the cover. Take the cover off, and then take the upper cover off. Underneath it is a switch. See if there is a piece of paper wedged in it. If so, remove it. Replace covers. If that does not solve the problem, then it probably needs feed rollers. You might be able to clean them with soap and water, but it will jam again in time.
Posted on Mar 01, 2008
Error E0
Error E0 results from the copier being turned off and on immediately after an error. Most likely there is another underlying error on your copier that needs to be resolved, but in some cases leaving the copier powered off for a couple hours can resolve the problem automatically. If you see another error code (most likely E000, E001, E002, or E003), your copier may need repairs.
May 10, 2012 | Office Equipment & Supplies
How can I solve error code E-1 on my gestetner 2722ztd photocopier? the error occurs when I turned on the power
u need to get a full error code press star or hash key to get the rest
my gues its 101 which is exposure lamp brocken or something to do with optics
Nov 02, 2010 | Gestetner Office Equipment & Supplies
Gestetner 2822 error code e-5
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
Nov 11, 2009 | Gestetner DSm645 Digital Imaging System
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
How can reset fixing error for gestetner copier
The Gestetner and Infotec copiers is based the RICOH.Please try the Ricoh sercice enter code (press total clear key(yellow) -1-0-7 and press and hold down the C key more 4 second.Eneter in the service mode and turn OFF the copiers,unplugged the cords.Wait 10 sec.amd plug in the cords and turn ON the power switch.If is not good the 107 code try 104 or 102.
Aug 19, 2009 | Gestetner Office Equipment & Supplies
We have a gestetner DSm622sp we are getting an error code SC320.
Hello sir; the error code you have display, that's means laser motor don't work, replace it!
May 18, 2009 | Gestetner DSm515pfd Digital Copier -...
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
ERROR UF-
I can help you, but what kind of copier is it? What make and model?
Mar 02, 2008 | Office Equipment & Supplies
UF Error code-Gestetner 2412Z
You may find it easier to solve the problem by asking the same question under its original manufacturer model........Mita DC1257
Good luck
Mar 01, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
99 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
