Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi TV Model VS-35313
Our TV tipped over and the plastic frame hit the ground. After that incident we get Vertical rainbows (blue, red, green and yellow). Objects on the screen have the vertical bands of colors. Befroe this incident the TV had been perfect. Your help is greatly appreciated.
Nikkname
  • Nikkname Mar 06, 2008
    I indicated the wrong Model NO. The correct Model No. CS-35313 is the TV experiencing vertical rainbows. Thanks for all the help I can get.
    NIKKNAME
    Sergeant:
    Champion:
  • 301 Answers
Probably having a convergence fail. if you are able check the solder connections on the convergence ICs on the large heatsink located on the middle PCB of the chassis. as long as the fail hasn't gone its coarse you may be able to correct the problem by a simple re-soldering of cracked(bad connection) pins.
Posted on Mar 02, 2008
Tv keep jumping at the top. the picture is green
This is likely a problem in a section called the vertical drive. A number of small parts need to be replaced. The green colour is due either to weak red an blue tubes or the green tube is over-driving. You might want to rethink spending any money fixing this...
Mar 30, 2010 | Mitsubishi VS-5047 50" Rear Projection...
My tv has many lines in the screen. what kind of problem is this and what does it need to be fixed?
You may be suggesting a convergence problem..when the blue and red boxes will not center. You have bad grounds on the convergence ICs. Resolder or replace theses ICs. Or you may be asking about a problem in the vertical section. Vertical problems will appear as horizontal lines on the TV. In this case you have bad capacitors near ithe vertical IC and must also resolder or replace the vertical IC.
Nov 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
