One of the bulbs are burnt out.I belive it's a 1157 bulb.The driverside window switch is bad and needs replaced.Check to see if power is going to the heater motor,maybe fuse.and last you might have a bad trunk release button.Hope this helps you please let me know.Mike
The signal problem is probably a bad flasher unit.it's located somewhere near the steering column under the dash. it's a small round silver (usually) part with 2 prongs that plug into the connector
