Question about Dymo LabelWriter 400 Turbo Thermal Printer
DYMO Labelwriter 400 stops printing half way through and an error message "out of paper" pops up. Then it continues to the next label but half an inch past the next label, then stops. I have tried label sizes, different labels, the same problem. It started when I changed a rool of labels. Before everything was running well.
  • 2 more comments
  • Costis Mar 01, 2008
    Thank you for your sugestion. Where can I find an option for the type of paper?
    Thank you for your sugestion. I still have the problem.
    Thank you again. I have the NEW DYMO Label Software Application Version 7.7 for Windows 2000/XP/Vista software installed and I cann not find the options you send me. I am sorry for getting back with this problem
  • Costis Mar 05, 2008
    It seems to be a hardware problem. Thank you
    Brigadier General:
  • 3,614 Answers
Be sure to set the type of paper you use, printer problem also occur if the type of paper is not set.
Posted on Mar 01, 2008
  • micromaster
    micromaster Mar 01, 2008
    Labeling Requirements List
    • Product dimensions
      minimum product dimensions
      maximum product dimensions
      continuity of product
    • Product attributes
      rigid or soft
      uniform or non-uniform
      empty or full
      cold or hot
      product material
    • Labeling surface shape
      flat or taper
      convex or concave
      oval or round
    • Label wrap needs
      partial wrap
      ½ round
      3/4 round
      7/8 round
      full wrap
    • Size of Label and Target Area
      Height
      Width
      Tolerances required
    • Side(s) to be labeled
      Top or bottom
      side or sides
      2 stage partial (folding stage)
      Neck
    • Speed required
      True end-of-line production speed (overall speed of the factory needed to keep product moving with realistic goals)
      Packing speeds
    • Production run lengths
      24 hour non-stop
      daily production stops
      Inline production not required
  • micromaster
    Hope it will do configure the system.
  • 790 Answers
HELLO!!
  • Kanth raj
    Kanth raj Mar 01, 2008
    Switch off the printer and disconnect the USB cable for 30 seconds. deep clean on the black head and try!!.
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
How to reset the dymo labelwriter 400 printer
Make sure you use original DYMO paper, otherwise the machine may be confused as to where to begin and stop. Also, cleaning the print head is a good idea if you have had the printer for a while.
The latest software is crucial. Right now it is version 8.4.2, you can see which one you have by clicking on Help > About DYMO Label.
If the above does not help, you are welcome to contact the DYMO help desk (dymo.com and select your country).
Dec 02, 2012 | Dymo LabelWriter 400 Thermal Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Feb 17, 2009 | Dymo LabelWriter 400 Thermal Printer
My Dymo LabelWriter 400 Turbo stops printing after it has printe
Did you change the number of copies to print prior to printing?
Jan 16, 2018 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
How can I fix this problem?
My printer is only a few months old. I have used up all the label roll that came with the machine and have put in a new roll (99010) which is slightly slimmer than the original one. I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label). HELP!
Aug 05, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
1,415 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
