Question about Xerox DocuPrint N17 Laser Printer
Printing grey pages
I have a docuprint n17 which has been great so far. I ran out of toner and replaced the cartridge but every page since is very saturated with toner giving me a gray page. I thought it must have been a faulty toner cartridge so I replaced it but the result is the same. If you can help I will be greatfull as this printer has a lot of life left
Did you leave the printer door open for more than 5 minutes when changing the cartridge? The OPC drum may be damaged by light
Posted on Apr 11, 2010
    President:
  • 2,072 Answers
First did you use a third party toner ?
If that isn't the case, try taking out the cartridges and looking for all the contacts. Clean them with a cloth dampened with a little alcohol. An improperly seated cartridge, with in particular a bad ground contact will cause that.
Less likely is the housing has gone bad. But still possible.
Either third party ink or a poor connection on one of the cartridges is the most likely issue.
Posted on Mar 01, 2008
Why is it when using black it only comes out grey on the far right side
remove toner and drum unit
remove toner
check to see if there is toner in the drum unit if not fill unit run 5-10 prints
replace dev roller
replace drum cylinder(opc)
Jul 14, 2014 | OKI C5150n Led Printer
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Black Prints
The toner might be bad, because the old cartridge is working fine.
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
Xerox DocuPrint P8 Laser Fuzzy Printing
Maybe a bad fuser . That would cause ghosting and reprint on the page
Feb 02, 2008 | Xerox DocuPrint P8 Laser Printer
N17 printing "black" pages
If it prints fine at times, I would go to the Xerox.com site and dlwnload the latest firmware, and install that.
The problem really sounds like corrupted software in the printer.
Jan 30, 2008 | Xerox DocuPrint N17 Laser Printer
OKI c5100 Printing GREY instead of BLACK.
Not able to print a status page. Tried holding down menu 5 sec and no output. I searched the menu and am not able to find how to print status page. I did print out a demo page and the black is great but when i print out text (like the entire menu map) the black is grey. Let me know if there is anything else I can do.
Jan 12, 2008 | OKI C5100n Laser Printer
The following link has a software and drivers where you can select MacOS X and find the software and drivers. Unfortunately I found no installation instructions.
Docuprint N17 Link
I hope this helps.
Dec 15, 2007 | Xerox DocuPrint N17 Laser Printer
Driver for windows vista
If found that if installed the printer as a Xerox DocuPrint 4517 instead of a Xerox DocuPrint N17b then the printer works fine under Vista.
The only thing that lead me to try this was that I found that N17b and 4517 used the same printer cartridges, so I guessed they might be similar under the hood too.
Nov 21, 2007 | Xerox DocuPrint N17 Laser Printer
Xerox DocuPrint N17 Laser Printer Logo
171 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
