Here is my 4 basic steps i give to you free .all iwant is a good review in return if it works. ok!
1.make sure you turn on faucet at sink until water is hot b4 you start the dishwasher.
2.add jet dry or rinse agent completely fill this compartment. 1 trick is to to do the up down up down up down on the door.then check dispenser and refill this will allow the air to come out and the dispenser to be fully filled
3make sure toadd the correct soap.
4.once the unit starts to wash check it to see if steam comes out when you open the door. if it does then everything is correct. let me know if my suggestions works by rating me with 4 thumbs if it work .thanks
i have the exact same problem as this lady, it's not my soap, it's not the water temp, the water is flowing into the washer with great pressure (i had a plumber come in) my clycles run right trough in normal washing time but the dishes come out dirty.
Did you find a solution to your question?
