Question about Philips ToUcam Fun II Webcam
Philips ToUcam Pro II - Astronomy imaging
I have a Philips ToUcam Pro II (PCVC840K) and am trying to get it to wrk on Vista int he same way it used to on my old XP laptop.
Whilst I can eventually get the drivers loaded using the workarounds suggested in http://toucam.philipspcstuff.com/ , when I am using Vrecord in Vlounge to start recording video it does not allow me to change the video properties so that I can adjust.things such as brightness, gain etc. When I go to the menu and choose Video Properties, nothing happens. This is essential for astronomy imaging applications.
I also noticed that the installer for this camera that comes on the CD does not run well on Vista with some USB string related errors.
Anyone have a solution to this? Is there some other software around that can run this web cam in Vista and allow video properties adjustments?
Cheers,
Jim
  • 6 more comments
  • katjim Mar 01, 2008
    unfortunately there is no option for updates in VRecord. According to Philips web site, they do not have any Vista upgrades...
    Cheers...
    The main issue I think is that the Philips tools are not installed correctly. There is a NoUSBString error.
    At best other programs can only control thisngs like brightness and contrast but not the gain which is needed for astropghotography...
    thanks for the info - unfortunately I need to run this in Vista - when I run this it still comes up with the NoUSBString error...
    installing the pcvc840k driver (for XP) on the Vista laptop gives same NoUSBString not found error...
    Hi - thanks for the tip - I had actually already tried this and whilst the camera works for windows functions such as msn, it won't work properly for the Philips VRecord program - I still can't get the advanced controls to work (wg. gain)...
    cheers,
    katjim
    unfortunately no - see my previous reply...I had already tried the unofficial driver, but there is still a problem in accessing the Video Properties in VRecord which means I can't change the gain of the camera...
    I have also tried the progeam Debut which also can make the camera function but I only have access to the Brightness, Contrast and Saturation controls...
    It looks like I may have to go back to XP to use this camera properly...
    cheers, katjim
  • katjim Mar 07, 2008
    Hi sweet_rascal - not sure why you didn't get my previous message - I actually already tried your suggestion and whilst the camera will work in a simple mode, I still cannot run Vrecord and get access to the advanced controls such as gain...I think I may have to go back to XP!!
    Cheers,
    katjim
  • katjim Mar 09, 2008
    hi pincer,
    not sure what happened, but your reply seems to be blank...
    cheers, katjim...
    Master:
  • 377 Answers
Good day!
pincer here..
Posted on Mar 09, 2008
    Guru:
  • 1,894 Answers
Hi.....is the cam detected by the vista???
Posted on Mar 01, 2008
  • 4 more comments
  • dewan nafees ahmed Mar 01, 2008
    here ...follow this
    howto
    Philips TouCam II PCVC840K on Microsoft Windows Vista (32-Bit)
    (Should also Work With PCVC720K-P PCVC730K PCVC740K PCVC750K
    NOTE: These are not official philips drivers.
    They do not support this driver. This is just a workaround that might
    enable you to install the webcam under Vista.
    1. Download the following file: Drivers
    2. Connect the webcam ( Windows wont find the drivers) However it does install the microphone driver.
    3. Go to the folder where you downloaded the files to and extract the File called: "Philips_Toucam vista.zip"
    4. Go to Start --> Computer Now select "System Properties" at the top of the screen.
    5. In the System properties screen, on the left select "Device Manager"
    6. In the Device Manager, under Audio there should be a Philips Toucam Microphone. Also there should be a unknown device listed.
    7. Now rightclick on the Unknown device and select: "update driver software"
    8. Select: "Browse my computer for driver software"
    9. Click on "browse" and select the folder where you extracted the files into.
    10. Click on next and wait till windows finishes searching. If you egt a warning select "Install this driver anyway"
    11. After this windows should gave you a message saying the install was succesfull.
    12.After clicking close the Device Manager Should look like this:
    13. Your webcam is now installed and
    functional in programms like MSN. There is no Philips software
    available for this device that runs in Vista.
    for doubts clarification...just have a look at this link
    thankyou ....
    regards
    sweet rascal....
    dont forget to rate the solution
    let me know whether this worked for you,,,,,,,,
    hello...did it work....
  • dewan nafees ahmed Mar 07, 2008
    what happened?
    Genius:
  • 1,226 Answers
Hello!
As far as i know that there is updates of this kind of cam, You can try downloading this driver IN XP ( this not run in other version of OS.) http://www.camera-drivers.com/drivers/126/126908.htm, you can run also for phillips drivers related errors.
Best regards, melnavz
  • 1 more comment
  • Emelio Navaja
    Emelio Navaja Mar 02, 2008
    Yep, why stake to other operating system in which all the functionality donot work, so XP is the best way. thats perfect operating system.
  • Emelio Navaja
    Emelio Navaja Mar 07, 2008
    thats really good idea to go back to windowsxp. this is most perfect operating so far. melnavz
  • Emelio Navaja
  • 790 Answers
    Brigadier General:
  • 3,614 Answers
On your camera menu there where you find an update options, where you can download for the latest firmware that defends on your system.
  • micromaster
    micromaster Mar 01, 2008
    inform when there's any info bout your cam
Cd will not load on vista
check for cd drive connections with data cable and power connections..
Sep 27, 2009 | Philips ToUcam Fun II Webcam
Where can i buy it? and how much
you can get it from amazon online here is the adress. please rate this answer i want your feedback.
http://www.amazon.co.uk/Philips-ToUcam-Fun-PCVC830K-Webcam/dp/B0009G3DG8
May 09, 2009 | Philips ToUcam Fun II Webcam
How to install philips web camspc620nc?
Go to
http://www.consumer.philips.com/consumer/en/us/consumer/cc/_categoryid_DRIVERS_AND_STORAGE_CA_US_CONSUMER/
& download the drivers
Here is another place for drivers
http://www.driver32.com/
Dec 16, 2008 | Philips ToUcam Fun II Webcam
Webcam problem
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, or shutting down.
Hope this is of some help. Bud
Jun 21, 2008 | Philips ToUcam Fun II Webcam
Uncompatibility windows vista and Philips Toucam pro
unplug camera locate drivers for vista download install reconnect camera
May 21, 2008 | Audio Players & Recorders
Can't get it to work
Try uninstalling the software and removing the camera from the usb port. Reinstall the software and reconnect the cam in a different usb port. If still not working try in a different pc to make sure the camera does not have a fault. If it works in another pc then the camera is not compatable as can happen on some pc's and you will have to try a different make of camera.
May 03, 2007 | Philips ToUcam Fun II Webcam
Philips ToUcam Fun II Webcam Logo
1,707 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
