Question about Archos 605 WiFi Digital Media Player
Error 102 How can I reset it by using a specific button, or get to the battery to remove it and reset ? Can I just power it off, plug in the USB and hold a specific button till it works ?
  • bily Mar 01, 2008
    I have problem error 102 for archos 605 wifi
    when i try to repair it didn't run properly and direct to first screen on archos...any body can help for this matter?
There is a very small hole on the bottom of the device where your unit would connect to a DVR base. Just to the left of the USB looking inputs, push a toothpick into the hole and that will reset the device.
Posted on Mar 01, 2008
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    Error code U052. I know this has to do with the chip in the ink cartridge. I changed all cartridges and still the same code. I cannot use any function on this MP530 with this error code.
    Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
    Please do this :
    1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
    2. Press the printer power button and keep pressed for 3 minutes then release
    3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
    Now insert cartridges and see if error goes away.
    Do not forget to rate my answer.
    Jul 06, 2011 | Canon PIXMA MP530 All-In-One InkJet...
    We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
    There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
    Mar 19, 2017 | RCA Audio Players & Recorders
    When I turn the camera on the screen shows a white light. No image
    1. Verify that the lens cap is not covering the camera lens.
    2. If operating the camera with a battery, ensure the battery is fully charged.
    3. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
    4. Verify that the LCD screen is turned on.
    5. Adjust the LCD brightness control.
    6. Change the shutter speed or aperture settings.
    7. If the issue is not resolved, try resetting the camera.
    Using an Initialize option in the menu
    Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
    Using a RESET button
    1. Locate the RESET button on the camera.
    2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
    3. After 2-3 seconds has elapsed, release the RESET button.
    Performing a manual power reset
    1. Turn off the camera.
    2. Remove the battery pack.
    3. Remove the button-sized lithium battery.
    4. Allow the camera to remain without power for 30 seconds.
    5. Reinsert the button-sized lithium battery.
    6. Reinsert the battery pack.
    7. Turn on the camera.
    Jan 01, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
    I turn camera on and this error comes up. turn the power off and back on again. I try this with no results.
    Solution
    sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
    Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
    IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
    Follow the appropriate procedure below for your camera.
    If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. Click the Repair & Status link on this page for available service options.
    https://eservice.sony.com/webrma/web/index.do
    Dec 25, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
    Hi i have sony h7 and wan to reset to factory
    IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
    Jun 26, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
    I cant get my ge usb wirelessmouse modle#98763 to work
    it is a plug and play device if the blue light comes on when plugged in it's working power wise anyway install all new batteries into the mouse press the blue light button on the usb and the little black reset button on the bottom of the mouse at the same time this should fix the problem if not you may have a port problem, the mouse/usb is bad or you're using vista which is nothing but a problem you'll need to install specific drivers then they do exist i've seen them just don't know the URL
    Dec 28, 2009 | GE Wireless Optical Mouse
    Battery on my garmin c510 sat nan wount hold a charge how easy is it to change
    Had the same problem. Fixed with a new battery. Takes the same as a Streetpilot c530 and can be purchased anywhere on line. A 10 minute job with a soldering iron.
    1. Open face plate. Unscrew 4 screws. Remove battery connector and clip.
    2. Unsolder the wires to the two speakers - 4 wires.
    3. Remove the sticky wrap from the old battery and place around the new one (to stop it rattling).
    4. Solder back the new speaker wires.
    5. Plug in battery, reassemble unit and charge Garmin off PC wih usb cable.
    Done!
    Sep 15, 2009 | Garmin StreetPilot C330 GPS Receiver
    Kenwood KDC-MP438U "USB ERROR"
    IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
    I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
    CLAUDE
    Dec 20, 2008 | Kenwood KDC-MP228 CD Player
    JUM Error 102
    Try to reset, firstly by removing the battery, leaving it for 30 seconds and power on
    Failing that ALT, RIGHT SHIFT and DELETE for a couple of seconds
    Jul 24, 2008 | RIM BlackBerry 7290
    Archos 605 WiFi Digital Media Player Logo
    98 people viewed this question
    Top Archos Audio Players & Recorders Experts
    kaiserh1
     Grubhead
    Grubhead
    Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
