Question about HP PSC 2175 All-In-One InkJet Printer
Paper loading I had a problem with the ink not moving now that is solved. Now i have paper in the printer but the error keeps coming up saying out of paper, what can be causing this and what can be done to solve it. I have a all in one hp pcs 2175xi it keep saying out of paper but its not
    Novelist:
  • 69 Answers
This is Vikram Kumar Thumu, I am from India- Hyderabad. I have seen your message and I would like to provide my solution on the issue.
Well, this issue could happen if there is any issue with Carriage Rod or if there is any issue with Print Spooler, or could also happen if there is any issue with Corrupted Printer Software
To resolve the issue, I recommend you to perform below solution :
Solution 1: Print Spooler
1. Please disconnect the Printer from Computer and then Power OFF Printer.
2. Then please next steps on Computer.
-- Click On RUN. this will open new window.
-- In the new Window, please type as services.msc and then click ok. Then a Services Window opens.
-- now please locate to the file that names as Print Spooler and then right click on the file and select the options as " Restart".
Once if you are done with steps, please restart the computer then connect the Printer to the computer and then Power ON printer...
I hope that this should resolve the issue. However, if the issue still persists then I request you to please contact at below web link, where you have an option by Phone Number or Email Support or Chat Support...
http://welcome.hp.com/country/us/en/contact_us.html
If you have any queries you can mail me at thumuvikram@rediffmail.com
Bye...
Posted on Mar 01, 2008
Paper cassette is not seated correctly. check for paper or objects blocking the cassette path. reinsert the cassette and press Start. keep getting this message. started after printing and installing...
I had this same problem and tried everything (I thought) to fix it. Then I saw the solution at:
http://www.retrevo.com/c/sohohelp/blogs/show/6633/I-just-had-my-espon-artisan-800-replaced-and-the-refurb-keeps-saying-that-the-paper-cassette-is-not-seated-correctly#replyForm
Basically there is a plastic pin that tends to break off and stays in the area where the cassette is loaded. It takes up just enough space to keep the cassette from being pushed in all the way. The solution is to turn the printer off, unplug it, then lift up the printer so the broken pin falls out. Once it comes out, the printer will work fine again.
May 12, 2011 | Epson Artisan 800 All-In-One InkJet...
It says that there is an error called 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon Pixma iP6600D InkJet Photo Printer
It says error 6a00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Feb 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
MY PRINTER SAYS ERROR 6A00
Hi
This error a lots The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Solution 2:
Solution 3:
Nov 20, 2009 | Canon PIXMA MP830 All-In-One InkJet...
For Canon mp210. Error light blinks. Either E22 or E2
Hi there
This is a Carriage error take a good look at the carriage that the inks are in and see if they are sitting ok and also do the next incise there some thing there stopping it from moving.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Nov 07, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer keeps on saying that there's no ink or paper but I just bought ink and there' paper in there. Can you help me?
i think it is asking for alignment page try this
before turning on the printer load the printer with paper and turn on the printer it will printer a alignment page and follow the instruction
hope this will solve your problem
Feb 02, 2009 | HP DeskJet F380 All-In-One Printer
My Printer says error code 6A00 What do i do?
Hi
Hope you come back
Solution 1:
Solution 2:
Solution 3:
Dec 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Please problem solve
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Paper loading
Make sure that there is no pieces of paper jambed around the wheels that pull the paper into the printer. Also that the back panel is fully locked into place.
Dec 20, 2007 | HP PSC 1610 All-In-One InkJet Printer
Canon Computer Pixma printer ip3000
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP PSC 2175 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
