Question about Microsoft Windows XP Professional
Window media problem
I am having problem with the window media player 11 ,the application is consuming more than 50% of my CPU when ever i start it.I tried with lower versions of it from window media 10and 9 too but they also have the same problem. What should i do to bring it back to normal...
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there
First things First:
1) What OS you got? I presumme windows XP home?
2) Uninstall all the Media Player 11 program and patchs.
3) Unistall all other media player like 7 or 8.versions.
4) install just the player from microsoft webpage ONLY!
5) if got more problem concerning hug application, consider a virus on your PC. or other hugging program instead.
Good Luck
Posted on Mar 07, 2008
How can you put music in it
Hi joe riri...
Try this method...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
Jul 02, 2011 | Philips GoGear ViBE Digital Media Player
Getting started download music from computer
Hi johnrober753...
Jun 01, 2011 | iRiver E150 (4 GB) MP3 Player
Please my w-player 10 is not playing ,i have more than 2000 songs the message is (an internal application error has occur) when i try to open it.
Try to install Windows Media Player 11
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
No playlist lost when you install WMP 11 (just update from 10 to 11)
Mar 14, 2010 | Computers & Internet
Removing Windows Media Player on my Desktop
Method 1: Uninstall Windows Media Player in safe mode loadTOCNode(2, 'moreinformation');
  1. Start the computer in safe mode. To do this, follow these steps:
    1. Restart the computer.
    2. Press F8 while the computer is restarting.
    3. Click Safe Mode, and the press ENTER.
  2. Click Start, click Run, type appwiz.cpl, and then click OK.
  3. Click Windows Media Player 11, and then click Remove.
  4. Follow the prompts to uninstall Windows Media Player 11, and then restart the computer when you are prompted.
  5. If Windows Media Player 11 is not removed, try Method 2.
uparrow.gifBack to the top Method 2: Run a program to remove Windows Media Player loadTOCNode(2, 'moreinformation'); If Method 1 does not work, you can use this procedure to uninstall the core of Windows Media Player.
  1. Click Start, click Run, type %windir%\$ntUninstallwmp11$\spuninst\spuninst.exe, and then click OK.
  2. Click Next, and then click Finish.
uparrow.gifBack to the topTo prevent Windows Update from downloading Windows Media Player 11, follow these steps:
  1. Click Start, point to All Programs, and then click Windows Update.
  2. Click Custom, and then click Software, Optional in the Microsoft Update Home pane.
  3. Expand Windows Media Player 11.
  4. Click to select the Don't show this update again check box.
    Note If the Don't show this update again check box is unavailable or dimmed, click to clear the Windows Media Player 11 check box, and then click to select the Don't show this update again check box.
  5. Click Review and Install updates to save the setting.
Jan 17, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Help needed !!! opened Windown media center earlier today, and now even with all applications shut down, the file wmpnetwk.exe is constantly using ~ 50% of my CPU. I Have ended the process with task...
Wmpnetwk.exe is a media player network sharing service. It is annoying and useless(as you have already noticed).
Click start->Run->Type in "services.msc"(without the quotes). Then click on the services tab, and uncheck the box next to wmpnetwk.exe. Click apply, close the configuration utility and reboot your computer. If you ever want to start the media sharing service again you can start it from windows media player.
Hope this helps,
Sai.
Dec 18, 2009 | Microsoft Windows Vista Ultimate Edition
Windows not not installing music files
To obtain windows media player 10, you will have to uninstall windows media player 11...the only way you can uninstall is if you have windows xp...To uninstall windows media player 11, click on start, control panel, add and remove programs, locate the windows media player 11 application then click uninstall...Once you uninstall the program restart your computer....You should have windows media player 10 now...
I hope that helps
Thank you
Belbwa
Feb 24, 2009 | Philips GoGear HDD6330 MP3 Player
I tried to download window media player 11
Try going into the control panel
Start>control panel>add/remove programs
Uninstall media player 11
If you really want to you can try to download and install again but it sounds like the file is messed up on the server you downloaded from.
Jan 26, 2009 | E-Machines T2615 PC Desktop
I am computer illiterate so this may be a long one. I have a Sansa Fuze MP3 Player 8gb Silver. Also I already have a Itunes account and library can I drop library into the Mp3 player or is their a website...
It is my understanding that downloaded iTunes music only works with iPod products. However, you can create your iTunes music into MP3 format in your iTunes library. Your MP3 player should come with the software needed or tell you which application to use (ex. Windows Media Player). After you've created an MP3 version you can import/export into the proper media application then sync to your MP3 player.
Info I found on the web about your MP3 player:
Compatible Formats
The player supports MPEG4 video files and audio files saved in MP3, secure and unsecured WMA, WAV, Audible, and Overdrive file formats.
Simply connect the player to a PC, and start dragging files from your Windows Media Player 10 or 11 applications.
Dec 27, 2008 | Audio Players & Recorders
I AM TRYING TO INSTAL MICROSOFT WMF 11 REDIST FOR MTP SUPPORT IAM GETTING A MESSAGE SAYING THE NTVDM CPU HAS ENCOUNTERED AN ILLIGAL INSTRUCTION. CS:07131P:OICSOP:6368617273 AT...
I AM TRYING TO INSTAL MICROSOFT WMF 11 REDIST FOR MTP SUPPORT I AM GETTING A MESSAGE SAYING that "You are not meeting the requirements".
What to do ?
Aug 20, 2008 | Computers & Internet
Uninstalling windows media player 11
Follow the process on the Philips website -FAQ, "I have upgraded my Windows Media Player from 10 to 11 and encountered problem with synchronization and detection of unit by PC? What could be the problem?"
-skip over the part about updating the device drivers if you wish
-Tha Mp3 Doctor
Jan 16, 2008 | Philips SA4020 MP3 Player
Microsoft Windows XP Professional Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
