Question about Bose Cinemate Digital Home Theater System Speaker
Door is stuck
My theater system's door won't open and eject the disc. It says on the display that the door is opening but it doesn't. Help!
  • 85 Answers
Just take rest the unit for 3 days,, then, if its not work.. you must open the unit and chek the railings maybe its just silicon grease stuk
Posted on Mar 01, 2008
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
The disc is stuck and the display reads "No disc".
Ok one easy fix to this is to tilt the player while the system is on whilst constantly pressing the eject button. I once had to even turn the whole thing upside down then back and shake a little until the disk positioned itself properly to eject. good luck
Mar 09, 2011 | Bose 3·2·1 II System
Have a dvd stuck in the unit. door will not open.
Your going to need to open this u if the door will not open and manually take the dis out by hand, now if you feel you cannot do that then your going to need a tech shop locally do it for you. But its easy you just pop off the screws the cover should slide oven you localte and take the disk out. now once your in there you can see if there was any damage 9 times out of 10 the disc got miss feed.
Good luck if you have any additional questions let me know otherwise please leave your positive feedbakc and ratings.
May 02, 2010 | Bose Lifestyle 38 DVD Home Entertainment...
Disc tray on Insignia BRDVD player will not open. Any help would be appreciated. Press the open/close button and display says either open or close. The tray does not eject though.
the disc is probably stuck out of the tray and stopping it from opening. unplug, and you should be able to pry open the front case and pull the tray out.
Apr 13, 2009 | Panasonic SC-HT730 System
Disc stuck in homethreatre system
you can try gently to get the disc,s towards the front of the player by turning it upside down ,then you can also try pluging it in and trying to gently pry the door open with the assist of the open button , if that does not work within a reasonalble amount of time you cac also take the casing off and reve the dvd,s that way ,just lay out the parts in order so you remember where they came from , hope i was able to help you , it happened to me already and once i had no choice but to take it appart and another time i was able to get them back into the vicinity of the inside tray and was able to open it that way , either way you choosae good luck and thank you for letting me hopefully help you Sincerely Glenn mayer
Mar 05, 2009 | Sony DAV-FR1 System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck
Aug 24, 2008 | Zenith XBS344 System
Won't eject DVD
I was able to fix this problem by disconnecting the Bose power cord from the back of the unit. When I reconnected it the door functioned again. Cleaning the disc helped avoid further lock ups.
Apr 02, 2008 | Bose (321GS) System
Disc tray
Something is causing the disc to get stuck inside the DVD player. Open it and inspect. If something is broken, take it to a repair center.
Aug 22, 2007 | JVC TH-A25 System
Bose Cinemate Digital Home Theater System Speaker Logo
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
