Home | HP | iPAQ hx2410 Pocket PC | Start up problems
HP iPAQ hx2410 Pocket PC
Problem for HP iPAQ hx2410 Pocket PC
Start up problems
By Stadil on Mar 01, 2008
I have upgraded to WM5, and for a couple of days everything worked out fine. Then suddenly the iPAQ started to freeze during start up. When I try a soft reset the process starts, but after 10-15 sec it freezes again and the screen becomes white. From there I have also tried a hard reset several times, but it keeps freezing during start up. I have charged the battery through the night but it does not help. Now I try to remove the battery for some hours and hope it will completely reset everything. Any other suggestions??
abh_stadil@webspeed.dk
Solution #1
posted on Apr 30, 2009
Not Rated)
permana_20
Rank: Apprentice
Rating: 0%, 0 votes
Tell me frankly,
did you really do hard-reset and the problem still?, my experience is that hard reset process is that it will do re-installing a default windows to your devices. If you sure it was a start-up problem, then the problem is solved already.
Unless the problem is similar with Ekse's one (it maybe after he/she 'googling' with few technician and got that result).
I suggest to re-flash your BIOS using PC.
Was this helpful?
Yes
No
Solution #2
posted on Mar 12, 2008
Not Rated)
Ekse
Rank: Guru  HP Expert
Rating: 88%, 4603 votes
I had the same problem few years ago with my 3950
I kept it on the charger and it just kept doing that, and finaly died totaly.
I send it to repairs and found out it was a motherboard / chipset problem and the motherboard would need to be replaced.
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ hx2410 Pocket PC
Questions and Unsolved Problems for HP iPAQ hx2410 Pocket PC
Do you recommend HP iPAQ hx2410 Pocket PC?
Answer
Answer
unit becomes warm with it switched off. batt also discharges.Its a 2400 series
Answer
the wifi is not working. have the message (uknown card in socket2)
Answer
hx 2410 will not start up. its been discharge for a while tried a hard reset but still does not... (More)
Answer
i have iPAQ hx2410 pocket pc and when i close it the instrumen tell me that i should re-enter new... (More)
Answer
I have IpaQ hx-2410 purchased 2nd hand last month, still looking for the wi-fi problem, it's keep... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP iPAQ hx2410 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 1457
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
