Question about Nintendo DS Lite Console
DS Lite touch screen
I've "calibrated" my touch screen thousands of times and the touch screen is COMPLETELY off center whenever I try to calibrate it, goes on constantly and doesn't stop OR improve the screen I've even tried cleaning it and that doese't work either all I can think of is a replacement screen but I've got NO idea on how to switch the two.
    Sniper:
  • 64 Answers
You'll need a tri-wing screwdriver, a small cross head screwdriver a new touch screen and a lot of patience.
1) Remove the screws from the botom case, 3 tri-wing, 3 cross head and the battery cover and battery.
2) Carefully split the bottom case and remove.
3) Open the clip that clamps the touchscreen cable from the back of the connector with a small screwdriver, just carefully lever up the back edge.
4) Carefully part the botom screen from the touchscreen.
5) Attach the new touchscreen to the bottom screen.
6) Re attach the ribbon cable to the clip.
7) Carefully refit the bottom case taking care not to break the power switch.
8) Re fit the screws.
HTH
Posted on Mar 02, 2008
Calibrate ds lite
If you would like to calibrate your screen...
Turn the DS on without a DS card inserted (or with auto mode turned off).
Then touch the DS icon in the bottom middle of the screen.
Press the far right yellow icon, with a crosshair in it.
You will then be taken to the calibrate screen.
Touch the small red squares on the screen as they appear.
Press confirm, exit menu.
Jan 06, 2010 | Nintendo DS Lite Console
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Nintendoe ds light touch screen wont work
use the regular control panel and go to the calibration thing then calibrate ur screen!
May 24, 2009 | Nintendo DS Lite Console
Stylus
Its not the styles it the ds
May 22, 2009 | Nerf Stylus Twin Pack for Nintendo DS...
Ds tough screen wont work (not the lite(the old kind)
try the calibration in the options. try tapping or if not working, use your buttons. tap or use the button to make the origin at the center of the screen.
Feb 11, 2009 | Nintendo DS Lite Console
Ds lite out of line (1cm out of where you touch on the screen)
Go to the main menu, then touch the mini DS in the bottom center of the screen. Touch the yellow icon farthest to the right. Follow the instructions from there on out. This is called calibrating your touch screen.
Hope it helps~
Jan 18, 2009 | Nintendo DS Lite Console
MY TOUCHSCREEN!!!
Mine was doing the same thing i replaced the touch screen and now it works fine.
Oct 25, 2008 | Nintendo DS Lite Console
Code insert buttons
Have you tried just using the Normal DS buttons rather than the touch screen? I don't know how bad your touch screen is calibration is for your AR (mines pretty close to fine), but if you find that the touch-screen is frustrating you too much, just use the normal DS buttons. Sure it will be a bit slower, but it won't be as frustrating.
Jun 23, 2008 | Nintendo DS Lite Console
Calibrating wont work.. i want to reset it
When you turn on the ds, go into settings (the center icon at the bottom), the press the yellow icon. I assume you got to that part.
Now you have to tap the calibration points; as you touch them, they should move to the next point (three altogether). Does that happen?
Next, you should be able to test it at four points. They will turn blue when you touch them. Does that happen?
If there is no response when you do this, your digitizer may be faulty.
The DS will reset to factory if you remove the battery. You need a small phillips screwdriver for that, on the bottom of the DS.
May 26, 2008 | Nintendo DS Lite Console
My screen wont calibrate
Do you mean you calibrate the screen and you can never accept the changes?
The lower screen in the DS Lite is actually 3 pieces. The lower screen, then the touch screen on top of it and then a clear plastic cover on top of that. If you are very rough with stylus on the clear plastic and leave dents or gouges this will damage the touchscreen.
From your basic description the touch screen needs to be replaced.
May 25, 2008 | Nintendo DS Console
Nintendo DS Lite Console Logo
182 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
