Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Red color border on the pitchures
My screen is showing red boader along the edges of the immages and lettring.
  • 116 Answers
Probably the convergence output integrated circuit is at fault. There are two-one for red and one for blue. They should both be changed. Also, sometimes the resistors feeding the I.C. may have opened as well.
Posted on Mar 01, 2008
DVD leaves 1/2 border on left side of screen in wide mode. what is Cinema aspect ratio for? Distorts Adjustment?
you have to adjust with the dvd players settings.
google your make and model #, manual and manual should show.
press the helpful button and follow me on fixya for more tips
Feb 01, 2016 | Proscan Televison & Video
When i print,the black colored lettres and lines show faded although i put a new drum. The colorprints are still good.
This problem arises if the printer is not used for along period/ might occur when the ink is change. Compare it to the case when a fountain pen is refilled. it takes a few time to get perfect flow.
This might be also due to the clogging of black ink inside.
Try the following operations from the printer properties dialog box:
Cleaning/ deep cleaning
Nozzle check
Hope this helped
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
The pitchure looks like its 3d. everything looks
You have a convergece board failure. Changing one board will not nescessarily fix it. It is recommended to change all 3 boards in the unit. many try this as a DIY and fall afoul because it is a specialist job to retune and reset the paramaters. The cost then becomes greater than if a tech did it correctly the first time. Be advised it is not a simple DIY.It requires soldering and desoldering skills, specialised tools and a knowledge of circuit diagrams.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Dell Latitude D620 Nvidia Quadro NVS 100m
Suspected it's a graphic error. Try re-installing your video driver to it's later version.
May 30, 2009 | Dell Latitude D620 Notebook
Words are doubled red borders???
Just to clarify, it sounds like what you are saying is that the image appears to duplicate in either red or blue along the edges of the image (especially white lettering and probably increasing along the boarder of the TV). This is resolved by converging your TV. Convergence will drift normally on large screen projection TV's over time or through moving them. The Hitachi 57f500a has a feature called "Magic Focus" (pg 36 in your manual) which will auto converge the image. If the auto converge feature doesn't work, on page 37 in your manual, it explains how to converge manually. If you do not have the manual, I have the image of the pages below. If for some reason this doesn't work, please provide additional info and detailed prior to rating the help.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
Blackening around edges of Philips 55PL 55" LCD
Check any magnet or some speaker are near ur tv . Off it for 1 hrs , re on it & check
Dec 23, 2017 | Philips 55PL9523 55 in. LCD Television
No bottom page border
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
