Help I have received a file (with some photographs) when i went to the file properties it is showing HTML file i and it is not opening. So please help
  • pk86bhat
    pk86bhat May 11, 2010
    file may not downloaded correctly or copying,u try with other explorer from now,
    and u must said error report,other than solution is not perfect
  • 99 Answers
Try to open your file, with windows explorer.its in the accessories.
Posted on Mar 12, 2008
I like to work with graphics
    There is a manual below or if you no idea where to find recovery file tool for illustrator, when learn next
    1. Close Adobe Illustrator.
    2. Right-click on the Windows "Start" button, and click "Open Windows Explorer, then the file manager opens. Navigate to the AI file to delete.
    3. Right-click on the AI file to show the context menu.
    4. Click the "Properties" option. The Properties dialog box opens.
    5. Uncheck (clear) the checkbox next to the "Read Only" option in the File Attributes section.
    6. Click "OK," and close the Properties dialog box.
    7. Right-click on the AI file, and click "Delete" from the context menu. Click "OK" to confirm the deletion. The AI file is deleted.
Nov 27, 2017 | Adobe Computers & Internet
My seagate 1Tb is actin strange.. when i try to explore it, it shows it's empty but when i check it through properties.. i have all my files hidden to it.. all my files got invisible.. please help..
Win 7 - open the drive on the computer, click the "organize" drop down menu on the left - go to "folder and search options" - select the second tab (view) - select "show hidden files, folder, and drives" - Hit apply then ok - all of your files should be visible now - select all files by hitting "CTRl" + "A" - right click on one of the files and select properties - uncheck hidden - when/if another window opens select the best option for you - now all your folders should be visible again - you can repeat the first few steps to make your hidden files invisible again if you wish.
Oct 15, 2013 | Computers & Internet
I have a external hard drive verbatium usb250 and i have saved lots of data on it thats one of a kind such as pictures of my daughters when they were born. well i went to access my pictures on the...
> i am so sad :( * I would be too. It sounds as if the hard drive is going bad possibly. You can try from within Windows > My Computer ... right click the drive, Properties, Tools, and try an Error Checking fix up of it. Otherwise I'd take it to a professional shop if the images are real important.
Nov 23, 2009 | Computers & Internet
Do not know to find a hidden window
If you have Windows XP, open up any folder, go up to TOOLS, then Click on Folder Options, After that click on the VIEW tab. You should now see where it says Advanced settings, go down and click on " Show Hidden Files And Folders"
For Vista Open up any folder, click on ORGANIZE at the top and scroll down to Folders and Search Options. Once in the Folder options click on the View Tab, you should then see where you can click on " Show Hidden Files and Folders"
I would suggest once you get that folder back, go back into the folder options and click on the Do Not Show Hidden files, because when you show the hidden files you are also showing important system folders.
Apr 09, 2009 | HP Compaq Presario SR2150NX PC Desktop
Screen keeps going off and on
I had a similar problem, but I got a picture before it broke up and went off. The screen was backlit, but no video (screen was receiving some power).
The LCD needs a very stable voltage to work, this is provided through the LCD connector ribbon. In my case the ribbon was damaged and replaced it.
I have had no problem since.
I discovered this through trial and error; I first changed my transformer power supply and then the video inverter card.
You may find the link below helpful as it contains articles that photographically show you how to open the laptop for repairs.
Hope this helps. (Please rate my advice)
Feb 21, 2009 | Acer Aspire 9300 Notebook
Message: Cant read file header.Unknown file format/file not found
First check to see what the settings are set on how the files are saved. If they are set to RAW mode you won't be able to open them. Set the camera to jpg mode. Then you will be able to open them. The RAW mode is an advanced mode that requires an advanced operator to utilize all of the fuctions.
Dec 30, 2008 | Nikon D40x Digital Camera
Problem with corrupted files
Dont panic... Just insert the memory stick in to a card reader and donot try to open it. but make sure that your memory stick gets detected.Then you can use any of the file recovery softwares to recover the photographs with out formating.I generally use the free app "PC file recovery". In case your memory stick is not detected in the first place, then There is no other option other than formatting. But the recovery software can recover 90% of the photos even after formatting.
If this doesnt work, post back. I will explain in more detail.
Nov 09, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Print Spooler has stopped.RPC server unavailable
I can definitly help you may take a few steps to narrow down this don't get frustrated! :-)
First lets start off by trying this:
Go to System Properties>Advanced
Select Performance>Settings
Select Data Execution Prevention
Select Turn on DEP for all programs and services except those I select
Click Add
Paste this in to the file name box of the window that opens:
Select Open
Select OK when you receive the warning
Select Apply
After doing that , follow my steps again for enabling the print spooler , let me know how that works
Oct 06, 2008 | Canon PIXMA MX310 All-In-One Printer
Psp memory card
Did you perform a system update recently? If so, you may have received a corrupted feed.
Jan 27, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
