Question about Canon PIXMA MP830 All-In-One InkJet Printer
Paper jam Can see paper when the rear cover is open but unable to remove the jammed paper.
My buddy Roy went in to have a look after I was ready to toss the copier, he moved the ink cartridge to the left and there was the paper jam. he used a flashlight and a pair of needlenose pliers to fish out the paper. Checking again there was more paper, that wqs saturated with ink. Clearing all the ripped corners out the display cleared to normal. There not kidding when they say to watch for curled or deformed paper in the feeder tray.....
Thanks Roy, Good Luck
Posted on Mar 05, 2008
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
There is a paper jam...how do I unjam it
Hi dorothyhover,
Here's how you would clear paper jam from your Brother HL 1430:
1. Remove the paper cassette completely from the printer.
2.
Pull any jammed paper up and out of the printer.
3.
Open the front cover and remove the drum unit assembly.
4. Pull any jammed paper up and out of the printer.
Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
6. Close the rear cover and install drum unit assembly, close the front cover.
Hope it helps.
Thank you for using Fixya.
Apr 28, 2011 | Brother HL 1430 Laser Printer
I HAVE A CANON PIXMA MP830 INK JET PRINTER WHICH HAS A PAPER JAM CAN YOU HELP
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have a paper jam with a samsung CLX 3175FN. Can't get the stuck paper out! Turning on and off didn't work.
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Nov 17, 2010 | Samsung Office Equipment & Supplies
The paper is jammed..
Cause and solutions for paper jams
Cause 1 : Paper jammed in the Paper Output Slot, the Auto Sheet Feeder, or the Front Feeder.
Soultion : Remove the paper following the procedure below:
1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
* IF the paper tears and a piece remains insde the machine, open the scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off and turn it on again.
-Be creful not to touch the components inside the machine.
*If you cannot pull out the paper, turn the machine off and turn it back on. The paper will be ejected automatically.
2)Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1 all the print jobs in queue are cancellled. Reprint if necessary.
if you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after moving the paper, contact your Canon service representative.
Cause 2 : Landscape credit card-size paper jammed inside the machine.
Action : Do not load credit card-sized paper in the landscape orientation.
Slowly pull out the paper from the Auto Sheet Feeder and remove it. If you cannot remove the jammed paper or the paper jam error continus after removing the paper contact your Canon service representative.
Cause 3 : Paper jammed inside the machine at the transport unit.
Action : Remove the paper following the procedure below :
!) Hold the Rear Cover Lever and then press to the right and put to remove the Rear Cover.
2) If you can see the jammed paper, slowly pull the paper out.
* Be careful not to touch the components inside the machine.
* If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
3) Reattach the Rear Cover.
Hold the Rear Cover so that the Rear Cover Lever comes to the left. Align the protrusions at the right edge of the cover with the slots at the rear of the machine and press on the lever ot reattach the Rear Cover.
Important : Press firmly on the Rear Cover until it is fit squarely in the rear of the machine. If the Rear Cover is not reattached properly, paper may not feed properly and cause paper jams.
4) If you were not able to remove the paper out in step 2, remove it from the Front Feeder. Refer to cause 1.
5) Relaod the paper in the Front Feeder and press the OK button on the machine.
If you turn off the machine in step 2, all print jobs in queue are cancelled. Reprint if necessary.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon PIXMA iP1300 Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Paper jam on Brother HL-1270N
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
    Make sure that the Paper LED is now off and the printer is ready.
Feb 23, 2009 | Brother HL-2040 Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
150 people viewed this question
old marine
old marine
