Question about Mitsubishi CS-35405 TV
My mitsubishi CS-35405
Set only has a thin line across,but sound is still there Is this something that I can repair myself ? I dont know much about TV's although I am very mechanically inclined.Is it worth fixing? I really like the set.Please help.Thank you
  • jmontejr Mar 01, 2008
    Thank you so very much for your expert advise on fix.I greatly appreciate it.
  • 2,336 Answers
This condition can be easily fix by replacing and IC that is the vertical amplifier.
The number is something like LA7835 or LA7836, this IC is mounted on a heatsink.
Do a search in google for it.
Posted on Mar 01, 2008
I have hooked up my tivo and cable box but can't get my dvd player or wii to work with my cs-35405. I can not afford a tv now so please help.
You may have to hook up the DVD to the inputs on the front of the TV. If there are not enough side or front inputs, you may have to run the game through the DVD player, if it has inputs.
Dec 09, 2014 | Mitsubishi CS-35405 TV
Where are the fuses in my mitsibishi TV ?
What is the model number? Download the repair manual to this set by internet. It will have all details.
Nov 30, 2012 | Mitsubishi CS-35405 TV
I have a Mitsubishi CS-35405. It has worked fine up until yesterday. When I turned it on the sound was fine but the picture is very blurred and the colors are pretty much all red and green. I tried the...
As old as this set is I worked on a lot of them.
Red and Green only?
These sets among other things with age develop bad solder connections: I suspect on the board that plugs onto the end of the picture tube you have some broken solder connections--the red, green, and blue video output circuit is there.
The really hard part with this set is just getting it apart--weighs a ton.
Let me know if I can help (not picking any set that heavy up).
Mar 31, 2012 | Mitsubishi CS-35405 TV
How can you adjust the color?
On your remote control, press video, will give you options to adjust, press video until it gives choice of color adjustment, press video agiain for tint, pressing again gives you other picture choices.
Nov 28, 2009 | Mitsubishi CS-35405 TV
No audio on mitsubishi model ck35804 picture quality is very good
Since I did not get a response.
I experimented and set up a dvd player with external speakers.
I know I'm not the only one waiting for a response, so its cool.
Jun 14, 2009 | Mitsubishi CS-35405 TV
Set only has a thin line across,but sound is still there Is this something that I can repair myself ? I dont know much... 1 Solution
This is a problem with the vertical circuit. It can be as simple as poor solder connections at the vertical IC or a defective IC. Look for a small flat IC attached to a heatsink with about 11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted as there may be other components that need to be replaced. If so, the symptoms will change. Report them here and we'll provide additional details.
Thanks,
Dan
Feb 23, 2009 | Mitsubishi CS-35405 TV
How to set inputs in Mitsubishi CS-35405
My cs-35405, only has input 1 and input 2, but has ant. A and ant.B So there are really 4 inputs. The input button on my remote, gives choice of these 4. Any vcr, dvd, cable or cable box, and satellite would be hooked seperatly on these. But to record TV, satellite or cable would need to go to recorder first and then toTV.
Jul 16, 2008 | Mitsubishi CS-35405 TV
Cs-35405 Black Box
Go page by page with the buttons on front of set ....what
you are seeing is called a text box and it is part of the CC feature...use menu & up / down....left / right buttons.....T.
Feb 29, 2008 | Mitsubishi CS-35405 TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Televison & Video Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
