Question about Gateway FPD2275W LCD Monitor
No Sound I have an old model, Norcent LCD 17" Monitor, model # LM1749B a friend gave it to me without any instructions. Where do I locate the sound? I want to make sure that I have everything correct. I only have one plug going to the pc, can you assist me with my problem? Thank You, GEMCAN1
  • 151 Answers
Plz check sound with speaker if there is sound then u can check or change cable that you are inserted in monitor plug .if it is ok then problem is related with monitor sound ckt plz change ic related with sound section
Posted on Mar 01, 2008
Norcent Technologies LM173SB 17 in. Flat Panel LCD Monitor Won't work with Windows 7
I ran into this very problem myself, the issue is that the monitor only supports 1280x1024 resolution MAX. Windows 7 cannot detect this monitor and so it does not know it is limited to this resolution, so Windows 7 is putting out a higher resolution at startup, thus the monitor tries to autodect for a second but then just goes blank because it doesn't understand (and can't display) the signal. The only solution is to use another monitor and adjust the resolution to 1280x1024 or lower, but I run into a problem where as soon as you remove the other monitor and restart, WIndows tries to "plug & play" the monitor all over again at startup. So you're best bet really is a newer monitor unfortunately, I only use my old Norcent monitor with my XP computer.
Aug 29, 2012 | Norcent Technologies LM173SB 17 in. Flat...
I need the ac adapter for the Norcent LM 730 LCD monitor.
That model uses a 12v 4 to 5 amp power adapter. Here is a link here you can get one.
http://www.ccl-la.com/catalog/product_info.php?products_id=48
I hope this helps, if so please rate my solution.
BuddyMc
Sep 24, 2011 | Norcent Technologies LM730 17" Flat Panel...
Tick tick sound appear from acer 15" crt monitor power supply circuit
the sound you heard come from power regulator. its just fine, just indicate that part are over heat.
maybe you ill consider replace your monitor with LCD. more friendly for your eye and less power consumption
Mar 08, 2011 | Acer AC 711 17" CRT Monitor
My norcent flat screen just blew out .. camn i get it fixed?
What is the monitor doing? Contact us at: tech@ccl-la.com or 318-447-9040
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 30, 2009 | Norcent Technologies LM730 17" Flat Panel...
Norcent lcd monitor shows the picture for a second
check your vga data cable. if you have another lcd just swap with the system and check it whether data cable proble or lcd.
Nov 21, 2009 | Norcent Technologies LM730 17" Flat Panel...
How do I turn the monitor volume on for a norcent
Please try to go to Control Panel > select Sound, Speech and Audio Devices > select Sound abd Audio Devices > then at Speaker Set-up select Monitor Stereo speakers. Best regards
May 12, 2009 | Norcent Technologies Computers & Internet
I have computor with Norcent LM 965WA monitor. Really liked the fact it had built in speakers. Worked great, now when I plug in the wire from compuitor to monitor, static but no sound. Any suggestions...
Hi and welcome to FixYa,
With your indulgence, pls verify that it is indeed the built-in speakers of the Norcent that is the issue. Temporarily plug in to the computer a pair of headphones or even an old external computer speakers. If sound, then the monitor speakers are verified, if likewise static, then it is a computer issue.
Let's try the easy one's first:
  • check/replace the cable;
  • try other ports to plug it in at the computer;
  • determine if the sound device/driver for Norcent shows up in your Device Manager;
  • determine if on Sound Property in COntrol Panel, the Norcent is selected as the default device;
  • you may want to update the firmware and driver available here.
Would appreciate a postback for any updates on any development(s) (or even the lack of any). Pls include what Operating System you are running and if the Norcent is using USB connectors or standard cables. Good luck and thank you for using FixYa.
Mar 09, 2009 | Computers & Internet
No sound coming from my Dell 173FP monitor
This monitor does not have built in speakers you will need to buy some... The AS 500 soundbar fits on to it but is now not available. See if you can find it second hand.. Or buy USB speakers that fit into the back of your PC as the mointor does not have any ports.
Nov 20, 2008 | Dell E173FP 17" LCD Monitor
Monitor shuts off after initial start-up
My 17 inch Norcent LCD was doing the same thing. Then after a couple of weeks the AC adapter failed. I got a new ac adapter now LCD is working.
Nov 21, 2007 | Norcent Technologies LM730 17" Flat Panel...
Gateway FPD2275W LCD Monitor Logo
118 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
