Picture cut off Screen on Tube TV
I have a 32" JVC tube tv. The picture on the TV is cut off on the edges. For example, "Seinfeld" shows as "einfed". think I may have pressed something on the remote although I have been though every setting on it, and nothing works. Please help.
  • 1 more comment
  • Mark S May 18, 2008
    I have a similar problem with my Apex PF2725. The image is a little too wide for the screen. Where I see a "TSN" watermark in the lower left corner, the T is missing. Simple image position/width adjustments are easy to accomplish on a computer monitor, so surely this can be easily fixed?
  • guycross Jan 08, 2009
    I have the same problem, I have a Bush TV (CRT) widescreen. No matter what screen setting I use some of the picture is cut off... I have tried TV settings and DVD player settings (there is only a DVD player plugged in, no other picture source).
    gc
  • shaysden Mar 02, 2009
    Apex 32" hd is cutting off the edge of the picture. It has always done this. How do you change the picture ratio to accomodate for the picture size?? Help! can't see the channel numbers in our guide!
  • 116 Answers
Is the extra width problem something new or has the condition always been there? If it is something new, probably the power supply regulator has failed causing overvoltage to the tv.
Posted on Mar 01, 2008
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Mar 06, 2011 | JVC AV-27730 27" TV
The screen will show a white line every few seconds, then will black out, this will go on as long as the TV is plugged in.
The Picture Tube of the TV must have got damaged. Give the TV to TV brand's technical support and change the picture tube, Thank You.
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Clean tv screen
Humid ( light-wet) towel is fine to clean picture tube TV.
Jan 09, 2009 | JVC AV-32D305 32" TV
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
Jvc tv
Before confirm the picture faulty go and the select the blueback option ON in menu option. Disconnect the cable signal and check the tv displays bluescreen. If it is there picture tube will ok, fault in C board. May be dry contact in blue output section the picture tube conducts heavily the respective color.
Sep 14, 2007 | JVC AV32F577 32" TV
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Tv problem
I assume you get a picture in there somewhere? The discolorization is caused by the degauser circuit malfunctioning or un-shielded speakers sitting too close to the TV causing magnatism in the CRT (picture tube).
Apr 08, 2007 | JVC AV-32F802 32" TV
Televison & Video Logo
994 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
