Question about Kenmore 62622 Electric Dryer
Idler pully What's up guys? I have an 80 series Kenmore dryer and the idler pulley came off during a move. The dryer is a couple years old but it was only used for about 4 months. It has been sitting in storage. :( When I put the idler in place, it doesn't even touch the belt and it wont stay in place. I don't think the belt is stretched cuz it use barely used. Why wont the idler stay in place and can the belt stretch without being used? Thanks for your help.
  • riat Jun 22, 2008
    hi i have a kenmore 11096210100. when i went to install the new belt,the idler pully was on the bottom of the dryer,just lying there.i just don't see where it hooks in.i've lined it up the way the diagram shows and attached the belt.dryer still won't turn.this is the third try and i'm frustrated.help please
  • abridges Feb 23, 2009
    idler pulley is off
I HAVE A KENMORE SERIES 80 HEAVY DUTY DRYER AND I NEED TO KNOW HOW TO PUT THE PULLEY BACK IN PLACE. THE PULLEY CLIP DOES NOT STAY IN THE POSTION THAT IT LOOKS LIKE IT SHOULD BE ON THE BOTTOM OF THE UNIT. WHAT I NEED IS A DRAWING OF SOME TYPE THAT SHOULD THIS AREA OF THE DRYER SO I CAN SEE WHAT IS MISSING.
THANK YOU ALL FOR ANY HELP/
OJ91
Posted on Sep 14, 2008
    Champion:
  • 249 Answers
There has to be a spring on the idler to keep it pulled against the belt
Posted on Mar 01, 2008
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
Cant install my belt back on my idler pully on my kenmore 80 series dryer . the idler pully i have is a piece of metal below but it does not open up so the belt will go through. i am missing something but...
Howdy: Check for the bolts that hold the pully on. Loosen the bolts and the pully should stat to open. You may have to put on the belt then install the pully. Look close at it. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
Kenmore 80 Series Dryer makes loud humming noise while being ran~
good for you a fixya girl. usually, the idler pulley fails. and is a gravy cheap fix. these are great dryer and worth throwing a few bucks at. spin all the pullies and a new belt is a good idea,
AND
How to Replace Kenmore Electric Dryer Idler Pulley How to
LET ME KNOW HOW YOU DID, THE PARTS SHOULD RUN UNDER $20 that's a cool fix !
Jun 09, 2017 | Kenmore Dryers
KENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Mar 02, 2009 | Kenmore 62622 Electric Dryer
Squeeking
most common problem is a bad idler pulley and/or roller assy, you can order a repair kit for your dryer probly under $40, includes new rollers, belt and idler pully part number 4392065
Mar 23, 2008 | Kenmore 62822 Electric Dryer
Dryer drum does not turn
how about the idler pully that keeps the belt tight did you see it in there has to be there look if its is ther try to turn the drum by hand a foregin object could be jaming the tub im here to help get back and let me know
Dec 29, 2007 | Dryers
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Kenmore 62622 Electric Dryer Logo
237 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
