Can't get sata connection to work on new blu-ray rom
Windows cannot find new blu-ray rom. device manager says there is something wrong with the sata connection. (This device cannot start. (Code 10)) on the "VIA Serial ATA RAID Controller"
Device is a LG GGC-H20L
  • Oilers5 Mar 01, 2008
    My motherboard is a Gigabyte K8VT800 Pro.... All the cables are connected, and the SATA control is enabled. This is the only SATA connection, with a hard drive, floppy, and a zip disk drive on IDE. I've tried a whole number of combinations of setting in the bios. Including changing SATA mode from RAID to IDE and GigaRAID Function from RAID to ATA. Everything I try ends up with the same error in windows but it will now recognize the blu-ray rom as IDE master 3 in the bios which it didn't before.
    Thanks for the help
    President:
  • 2,351 Answers
Oilers5, let's check a few basics first. Double check your dvd's data & power connections first. Everything good? Next, you need to get into your bios. Your blu-ray is connected to the SATA controller on the motherboard. Though I do not doupt the device manager your bios must see the device before windows will. At the main menue in your bios the DVD player should be listed (depending on model # of board) at the main menue. Than make sure the SATA controller is enabled, you'll find this in advanced menue. This is where you'll need your manual. If the dvd is the only SATA connected to the system you should have the option to use the SATA & not the RAID. If you have SATA hard drives connected & your dvd ends up on the RAID end you still should have the option to set the RAID to IDE. This way you will not need to run the RAID software. Once you get the bios adjusted windows should see the blu-ray as a SATA dvd player.
Oilers5 if what I have listed has not helped or fixed your problem could you post back with your model no# of the motherboard. Mfg's name ex; (dell, HP...). Than I can download your manual & check what settings need to be adjusted. Is this the only SATA device your trying to get to run? Is your current hard drive a SATA or IDE? How many?
Thanks Oilers5. I look forward to your next post.
Posted on Mar 01, 2008
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
The drive is not being seen in windows 7
Is This recently installed drive? It could be missing drivers. click on start then right-click computer, and click properties, then on device manager a new window should pop up with a list of devices under cd/dvd rom drives check to see if your device is listed.
Jun 02, 2011 | Lite On LITEON DH16D3P-04 16X IDE DVD ROM...
I'm assembling a new computer and the new Sony DVD Rom DDU1681S-0B (SATA) is not being recognized in the BIOS. I've got an ASRock 939Dual-SATA2 - SATA motherboard. I've got it plugged into the SATA...
you might have to physically unplug the leads for this dvd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 20, 2011 | Sony 16X DVDROM SATA DVD Drive
My cd-rom can't read CD-R??!
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Nov 25, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Asus e818a3t is recognized as a DVD-ROM only. I can no longer write CDs after my Windows 7 Pro 64-bit install. Windows says the driver is installed and everything is working properly. Obviously not!
Hello there,
Try this trick,
1. Go to Hardware Profile and Remove your Asus ROM profile.
2. Shutdown your Machine -
3. Remove the Asus ROM from your Sata Connector.
4. Turn your Computer ON without that ROM
5. Shutdown it again, and Reconnect your ROM to those Sata connectors
6. Comment back here if still not working. :)
Cheers!
Aug 20, 2010 | ASUS DVD E818A3T - Disk drive - DVD-ROM -...
My dvd does not appear in my computer or device manager
Check the SATA/IDE connection and make sure it is securely connected to the mother board and the drive, and that the power connector is securely connected to the drive. If you cannot see the drive in the BIOS, then you have a bad drive or bad connection on the mother board.
Feb 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Hi, My dvd drive does not show any more on "my computer" and has stopped working. I have put in a new dvd drive - no luck! The device manager tells me the "driver fails to load" but when i try to update...
Make sure the dvd drive ribbon cable is in the socked as tight as it can be, and it is on the secandry socket on the motherboard, not the one that connects to your hd.
Put the dvd-rom on the last socket of the ribbon cable and adjust the jumber on the back of the dvd-rom to master.
Take all other ide or sata divices out and put them back afterwards.
Jan 22, 2010 | Computers & Internet
DVD-ROM of my laptop is not working
What is the specs of the laptop?
Feb 10, 2009 | Toshiba Televison & Video
Computer will not boot with Pioner Blu-Ray BDC-SO2 installed.
Hi stokarek,
With respect to SATA drives. All are master drives. As you mentioned if there is a fight between drives the trouble can be settled in the bios. I gather the WD160GB drive holds windows on it & the WD is connected to SATA 1 port. Enter you're bios & go to the Boot section. Open you're manual to section 2.6 boot menu page 2-32. Make sure you're WD is the only hard disk drive listed. After you add the Blu-Ray (To SATA 2 port), (its pin setting should be set as master. Than go back to the boot menu & make sure the Blu-Ray drive is listed under the WD drive.
Keep in mind for the future that if you want to boot to the Blu-Ray drive you'll need to press the F8 key at boot up. Windows select boot device window will open & high-light the Blu-Ray & press enter so the Blu-Ray will boot. Windows should no longer stall. If this does not work try switching the pin on the blu-ray to slave. (I'm not sure there is even a pin setting on the blu-ray drive. Never the less the bios boot order is the boss.
Link to Asus main driver site for ASUS M2N8-VMX
http://support.asus.com/download/download.aspx?modelname=M2N8-VMX&SLanguage=en-us
Good Luck stokarek!
Mike
Jul 08, 2008 | Acer AOpen MX 3ZA (91.88110.101)...
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
