Question about DXG Technology DXG-305V Digital Camera
Installation for the downloading in the computer
The disk to download pic - I can't install Say the screen resolution to executive digital camera solution disk is not sufficient
  • 4 more comments
  • Anonymous Mar 29, 2008
    Yes
  • Sabyiah Apr 01, 2008
    where can I guy the software disk
  • Anonymous Apr 15, 2008
    i cant get the pictures off my camera because i dont have the disk to the camera
  • ciriloa Jul 09, 2008
    Hi: I have the same problem and being in the computer looking how to fix the problem no one can"t help. solution disk is not sufficient
    Canon SD850 IS Digital IXUS 950IS DIgital camara
  • Anonymous Jul 11, 2008
    When trying to install Digital Camara (Power Shot S5 IS) Solution Disk to computer I get the following message: The screen resolution to execute Digital Camara Solution Disk is not sufficient. What should I do?
  • sylkap Aug 21, 2008
    I have same problem ("screen resolution not sufficient to execute Canon PS software"). Don't understand this, I looked at my manual from my other (Fuji) camera and it calls for the EXACT SAME screen resolution as the Canon manual.....and my Fuji software disk loaded just fine. Anyone find an answer yet? Or a way to get your camera photos onto the computer WITHOUT the Canon software?????
Hello! you speak portuguese!!
Posted on Nov 22, 2008
The installation disk is not working
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 03, 2009 | Canon PowerShot A470 Digital Camera
I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Dec 30, 2008 | Canon Cameras
Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Can't install the solution disk
Click on "Start" lower left corner of your screen, and select "Control Panel". Then double click the "Display" icon. Then click on the "Settings" tab.
Slide the screen resolution slider bar 1 click to the right to select 1024 x 768 resolution. Then click OK. You should be able to install it now.
Apr 12, 2008 | Canon PowerShot A450 Digital Camera
Canon powershot sd850 is digital elph
Hi
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Thomas
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
DXG Technology DXG-305V Digital Camera Logo
70 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Derick Williams
Level 1 Expert
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
