I somehow ''hid'' all the applications on my home screen and I can NOT get them back...my ball and [black berry button] dosent dsplay anything, plese help
There's No such a reset button in Black berry phones you just need to do is remove the battery and then put it again. to see more Black berry Problems and solutions Click here
Roller ball stuck: get some denatured alcohol put it on a dry paper<br />
<br />
towel then press on the roller ball. work it back and forth, until<br />
<br />
all the grit and dirt is removed. good luck!
A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
it is because of the dirt that reached under yhe ball .if you can remove easily your phone's trackball then takeout that ball and clean it with a soft cloth an put it back. otherwise i will recommend u to take it to the service centre if u are not comfortable in this.
there is probably a problem with the contacts from the home button to the actual phone... okay get ready this is going to be long haha
take out the screws from the bottom of the phone,
put a suctioncup on the glass of the phone and pullup,
the screen will separate from the body,
you can then see the home button from underneath,
check the contacts on that and the phone,
if they look fine then put it back,
still doesnt work?
replace it, buy an iphone home button off ebay and replace it on the phone.
you need to connect the phone to the computer or laptop that you are using via usb cable and open teh blackberry desktop manager and go to application loader and install the OS you want and it will be up and working great again.
